Author Topic: X2 Series V3 skin "FleurBall_v2" by Unreal  (Read 14165 times)
Offline Unreal
    • UnrealRG Home Page
« on: May 01, 2014, 08:57:54 PM »
FleurBall_v2
Startup Screen:
Home Page:
Genre Icons:
I really like the new features of the V3 firmware for the X2 and the "ThatTheme!" skin.  However, I do not like how big the options are on the home page, so I wanted to create a clean, streamlined skin that maximized the area for the wallpaper background.
The FleurBall_v2 skin will only work with X2 series firmware version 3.0.2 or higher, and includes a new startup screen, new homepage wallpaper, new buttons, modified TV Series episode tiles, and new matching genre icons for the Favourites menu.  I setup my X2 so that all of the media is accessible from Favourites, so I renamed the button for it to "Media".  I also renamed the button for "Media Library" to "Devices" because I felt that was a better description for that section.  The other two buttons, Internet and Setup, are unchanged.  If you experience any problems using the skin, please let me know.
How to change a skin:
To load a skin -- just download it and unzip it to a folder.  In X2 navigate to this folder and press the ‘Menu’ button and select the ‘Set to Skin' option.  The new skin will be loaded into flash memory and used as the new default.  You can revert back to the original default skin at any time by selecting the option ‘Restore Default Skin’.
I hope you enjoy the skin!
-Unreal
Download link:
http://www.mede8er.org/skin_pack_downloads/X2_V3_Series/X2_Series_V3_FleurBall_v2_by_Unreal.zip
« Last Edit: September 03, 2015, 06:44:46 PM by Maasbommel »
MED450X2 with PCIe Wireless                                 Firmware 3.0.2, NAS off, DLNA DMR&DMS enabled
Samsung USB Drives [2x2TB] (HX-DT020EB/B62)      Asus RT-N66U Router (FW 3.0.0.4.260)
Re: X2 Series V3 skin "FleurBall_v2" by Unreal
« Reply #1 on: May 13, 2014, 06:57:03 PM »
bump - download link to the V2 skinpack now added.
Sorry for the delay.
Offline Unreal
« Reply #2 on: May 13, 2014, 09:45:46 PM »
Thanks for the upload Maasbommel.
Offline Unreal
« Reply #3 on: May 13, 2014, 09:48:10 PM »
Updated the first post with additional screen shots.
« Last Edit: September 04, 2015, 12:11:30 PM by Unreal »
