Author Topic: Apple users - must read!  (Read 13917 times)
« on: March 31, 2014, 09:51:56 AM »
There are a number of Apple Tips of varying degrees of importance.  This sticky will list "all" of them as they  are found.
Procedure for formatting Single partition MAC HFS+ Volume on USB Drive (MAX 2TB):-
http://www.mede8erforum.com/index.php/topic,13976.0.html
If you do not create a non bootable MBR partition as above, you may need this tip:-
Procedure to remove EFI partitions on GPT Mac OS X formatted disks
http://www.mede8erforum.com/index.php/topic,14019.0.html
Apple 4cc code fix
http://www.mede8erforum.com/index.php/topic,14311.0.html
Step by step network set up for Mac - MED600X3D
http://www.mede8erforum.com/index.php/topic,10091.0.html
Mac users, X2/X3 series'  Jukebox and DuneX: the solution is here!
http://www.mede8erforum.com/index.php/topic,8553.0.html
Use Music Jukebox Tagscanner on Mac
See FAQ item 9
http://www.mede8erforum.com/index.php/topic,7828.0.html
« Last Edit: May 13, 2014, 05:59:54 PM by jer1956 »
