Author Topic: V3.0.4 - 27March 2014 BETA X3D Series - for MED1000X3D - MED800X3D - MED600X3D  (Read 13153 times)
  • Helpful Contribution Status: +94/-20
We urge you to firstly read the V3 Specific User Manual before just making posts about things not working correctly.
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc
Win7, 8, 8.1 users - Safe Removal is incompatible with the linux NTFS code. Instead use Utility to Eject the Mede8er (or shared external USB drive) - USB Disk Ejector  http://quickandeasysoftware.net/software/usb-disk-ejector
Vanishing files and un-mountable partitions can occur as  a result of using Safe Removal. Those should get fixed by using slave mode, running chkdsk and removing the player using the USB Disk Ejector tool.
New Scraper Skin
1. Fixed skipping 2nd line of external srt subtitles
2. Fixed - jukebox+: after installing new firmware cannot set 'Aggregate JukeBox' to old JukeBox+ folder.
3. Feature: add Auto Standby for ERP, and default set to OFF
4. Feature: setup option: add a new option for 'xvYCC' control - to fix Darbee issue - must restart movie for new setting to take effect.
5. Fix Green screen when in Video Preview and pressing 'Home' or Power' button on remote.
V3.0.4 - 17March 2014
1. New Default Movie Scraper skin to accommodate longer plots
2. Updated TV Series Skin
3. Movie Scraper - select image to match the Scraper Language and if not found use the English image.
4. Movie Scraper/TV Series Scraper - If plot not available in Scrape Language then English will be used.
7. Improved look for incorrect aspect ratio poster images on tmdb such as French/Italian
8. Added NanumBarunGothic.ttf as default font for Korean
9.Increased Koren font size on about.jpg with Internal scraper
10. Fix. French translations
11. Updated German for Return - "Zurück"
12. Added Language Localization for new strings
13. Fix - Show the correct name for .web file in list view.
14. Fix - IPTV
15. Fix: Nav Up/Down with DVD/ BD
16. Fix: Missing Index when navigating Movie JukeBox
17. Fix: Initial Setup Manual Settings Time Option
18. Fix Mini Keyboard to be able to change Languages
19. Fix: USB Power off as reported by some users
20. Updated Hungarian String Table
21. Dev: Added .web icon on Internet Page for Internet Radio or any web url support.
Default .web is BBC Radio Stations via Tunein Radio
Make your own .web file and import it into the GUI.
Download .web example http://www.mede8er.org/artwork/temp/2014/.WEB/320khz_radio.web
Dutch Radio Stations: http://www.mede8er.org/artwork/temp/2014/.WEB/NL_radio.web
Save the .web file anywhere. Navigate to the file and focus on it and press 'Enter' and it will be added to the .web screen.
You can remove any .web link by pressing the 'menu' button and selecting 'Remove'
STEP1    IF YOU ALREADY INSTALLED V2 OR USING MED800X3D YOU MUST SKIP STEP1
STEP2
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2013/X3D_Series_V3.0.4_27March2014_BETA.zip
Instructions to convert existing collection for new Scraper Skin - about.jpg
Focus on the root folder of the Movie Collection and select the option 'Clear about.jpg.
Focus on the root folder of the Movie Collection and select the 'scan' option and the about.jpg's will be rebuilt.
Update movie plots etc
Delete xml files and 'Scan' again
X2 Skin for X3D Series
Note: this skin will only work correctly with V3.0.2 or higher
http://www.mede8er.org/skin_pack_downloads/X3/X2_Skin_for_X3_15Dec2013.zip
Red Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Red.zip
Blue Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Blue.zip
Green Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Green.zip
Yellow Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Yellow.zip
New TV Series Skin
JukeBox+ Online Guide
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and then hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
« Last Edit: August 08, 2014, 03:28:45 pm by Mede8er1 »
Due to  a typo  the ID number was not raised. It is really the first 3.0.5 public beta.
