Author Topic: Alternative X2 Movie Scraper Skin  (Read 18267 times)
« on: March 06, 2014, 06:13:40 AM »
http://www.mede8er.org/skin_pack_downloads/X2_V3_Series/X2_Alternative_Scraper_Skin.zip
Instructions: Download and unzip  - In Media Library navigate to the folder 'X2_Alternative_Scraper_Skin' and press the 'Menu' button and select option 'Set to Skin'
To update existing Movie Sheets to the custom Scraper Skin - Navigate to the root folder that holds the movies and press the 'Menu' button and select option ' Clear about.jpg' - Rescan the folder and the Movie Sheets will be made with the new skin.
Offline Gogsysul
Re: Alternative X2 Movie Scraper Skin
« Reply #2 on: May 24, 2014, 12:35:15 PM »
Thanks m8.
Grabbed, and when I get time will have a fiddle and see if i like it and replace the other one.
Offline Unreal
    • UnrealRG Home Page
« Reply #3 on: May 25, 2014, 05:48:12 AM »
It's just personal preference and the differences are subtle, but I like this "alternative" skin better.  I re-scraped all of my movies to use it.
MED450X2 with PCIe Wireless                                 Firmware 3.0.2, NAS off, DLNA DMR&DMS enabled
Samsung USB Drives [2x2TB] (HX-DT020EB/B62)      Asus RT-N66U Router (FW 3.0.0.4.260)
« Reply #4 on: May 25, 2014, 08:24:23 AM »
Those interested shouldn't be put off by the idea of rescraping. In realty all that happens are the abouts are rebuilt using the scrape you already have. It doesn't take that long.
