Author Topic: Game of Thrones and other Series  (Read 4659 times)
Re: Game of Thrones and other Series
« Reply #1 on: February 20, 2014, 10:44:08 am »
They are using a movie scraper to do that. Some people are happy to have each episode in its own folder to use the "about" image.
A TV scan  will not do  this.
You could create a dummy movie jukebox not using TV series in the name....with a one dummy mkv for each  season.  Then  scan/scrape that.   Then  copy over the abouts, one for each season, to  the TV Series folders.   You would only see it if you  select Info.
« Last Edit: February 21, 2014, 11:26:38 am by jer1956 »
Offline defetonezzzzz
« Reply #2 on: June 25, 2014, 07:48:26 am »
although stat rate in my opinion is arguable from case to case.
