Author Topic: V3.0.2 - 18Feb2014 for ME500X2, MED450X2/S, MED400X2/S  (Read 22760 times)
  • Helpful Contribution Status: +98/-24
« on: February 18, 2014, 05:37:01 pm »
Hi All X2 Users
Download X2 Series - V3.0.2 - 18Feb2014
http://www.mede8er.org/Firmware_Final/MED500X2/X2_Series_V3.0.2_Feb18.zip
Changelog  V3.0.2 - 18Feb 2014
1. new - default GUI - Removed Default Realtek search Icons and functionality
2  new - Movie Scraper App
3. new - TV Series Scraper App
4. new - WOL (Wake on LAN)  - WOL
5. Updated DLNA DMS / DLNS DMR
6. Updated images for DLNA music playback to match the rest of the GUI.
7. Dev: shortcut key: RED/F1 to toggle DLNA DMR, and GREEN/F2 to toggle Upnp Server on Home Page or Favourite screen only.
8. Dev - In Movie Play the Nav Up/Down moves srt subtiles up/down
9. Dev: added grey color option for subtitles
10. Added Return Icon in Setup Menu
11. Fixed - Music Play keeps repeating. Now after the last track the music play stops
12. Dev: rss: update VideoPodcast Rss from ftp as X3D.
13. Dev: Added watched indicator for list View of TV Series.
14. Added - Compound Filtering in Movie JukeBox
15. Added - 3 Row Movie JukeBox - Select 'Hide Movie Info' in Movie JukeBox to enable 3 Row View
16. Added - Watched/Unwatched filter for Movie JukeBox searching
17. Added - Watched Indicator icon on Thumbnail.
18. New Functionality Mede8er JukeBox Plus
19. Fixed - Flac cue and noise problem
21. Fix - Flac cue file 'index' problem
22. Fix: audio playback: when set to 'repeat OFF', end of last tract then with FLAC+CUE, system will crash.
24. Dev: jukebox: reset JukeBox filter data after exit
25. Added support for exFAT drives
26. Dev. Added NFS Setup Option - Setup --> Network --> NFS
27. Dev. Internal HDD Format - one single NTFS Partition
28. Fixed. Scanning Movie and TV Series in Media Library
Alternative X2 Movie Scraper Skin
http://www.mede8er.org/skin_pack_downloads/X2_V3_Series/X2_Alternative_Scraper_Skin.zip
Scraper skin Yadis style
http://www.mede8er.org/skin_pack_downloads/X2_V3_Series/X2_Scraper Skin - Yadis look_V1.zip
Instructions: Download and unzip  - In Media Library navigate to the folder 'Scraper Skin - Yadis look' and press the 'Menu' button and select option 'Set to Skin'
To update existing Movie Sheets to the custom Scraper Skin - Navigate to the root folder that holds the movies and press the 'Menu' button and select option ' Clear about.jpg' - Rescan the folder and the Movie Sheets will be made with the new skin.
Online Movie Scraper Guide
Online Jukebox+ Guide
JukeBox Plus
JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files. Do not set the favourite link to  an actual jukebox as the jukebox+. Using jukebox+ Reset may then delete your media!
If you  find your self in this position, remove/disconnect the host store for the jukebox+, and then perform a Reset Jukebox+. That might require you shutdown first and remove drives, lan  cables etc.   After doing the reset, shutdown again, are reconnect the removed storage.  Favourites will now show "all"  the links including a working jukebox+,  but the Menu  now has the Aggregate Jukebox option to  create the dummy you should have in the first place.  Until you  do  that, Add to Jukebox+ won't appear again. You can then  turn the wrongly used folder back to  a media store.
JukeBox Plus Instructions
Emergency Procedure
« Last Edit: May 22, 2014, 05:24:18 pm by Mede8er1 »
