Author Topic: X2_Series_V3.0.2_14Feb_Beta  (Read 3930 times)
  • Helpful Contribution Status: +94/-20
« on: February 15, 2014, 01:56:23 pm »
Hi All X2 Users
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc  Those who have not used 2.1.1 must do  this. The code only adds Volume Names to virgin  drives when they are formatted.
Vanishing files and un-mountable partitions can occur as  a result of using Safe Removal.
Download X2 Series - V3.0.2 - 14Feb2014
http://www.mede8er.org/beta/Firmwares_Beta/X2_Series/X2_Series_V3.0.2_Feb14_Beta.zip
Changelog  V3.0.2 - 14Feb 2014
1. Dev. Removed Default Realtek search Icons and functionality
2. Fixed. Scanning Movie and TV Series in Media Library
NOTE: Old X2 skins are not compatible with V3.0.2 and up
Changelog  V3.0.1 - 20Jan 2014
1. Fixed - Flac cue and noise problem
2. JukeBox + - will only allow empty folders to be made into a JukeBox+
3. Fix - Flac cue file 'index' problem
4. Fix: audio playback: when set to 'repeat OFF', end of last tract then with FLAC+CUE, system will crash.
5. Fix: menubar: the background of nfs proble
6. Dev: jukebox: reset JukeBox filter data after exit
7. Added support for exFAT drives
Changelog  V3.0.0 - 29Oct 2013
1. new - default GUI
2  new - Movie Scraper App
3. new - TV Series Scraper App
4. new - WOL (Wake on LAN)  - WOL
5. Updated DLNA DMS / DLNS DMR
6. Updated images for DLNA music playback to match the rest of the GUI.
7. Dev: shortcut key: RED/F1 to toggle DLNA DMR, and GREEN/F2 to toggle Upnp Server on Home Page or Favourite screen only.
8. Dev - In Movie Play the Nav Up/Down moves srt subtiles up/down
9. Dev: added grey color option for subtitles
10. Added Return Icon in Setup Menu
11. Fixed - Music Play keeps repeating. Now after the last track the music play stops
12. Dev: rss: update VideoPodcast Rss from ftp as X3D.
13. Dev: Added watched indicator for list View of TV Series.
14. Added - Compound Filtering in Movie JukeBox
15. Added - 3 Row Movie JukeBox - Select 'Hide Movie Info' in Movie JukeBox to enable 3 Row View
16. Added - Watched/Unwatched filter for Movie JukeBox searching
17. Added - Watched Indicator icon on Thumbnail.
18. New Functionality Mede8er JukeBox Plus
JukeBox Plus is new functionality within the X2 Firmware that will allow you to Aggregate your Movie JukeBoxes across different sources such as internal Hard Drive, USB Drives and Network shares both Samba and NFS. There is no limitation to the amount of Movie JukeBox's that can be added to JukeBox Plus and just remember that the source shares must have the required Mede8er folder structure with the correct images and xml files.JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files. Do not set the favourite link to  an actual jukebox as the jukebox+. Using jukebox+ Reset may then delete your media!
If you  find your self in this position, remove/disconnect the host store for the jukebox+, and then perform a Reset Jukebox+. That might require you shutdown first and remove drives, lan  cables etc.   After doing the reset, shutdown again, are reconnect the removed storage.  Favourites will now show "all"  the links including a working jukebox+,  but the Menu  now has the Aggregate Jukebox option to  create the dummy you should have in the first place.  Until you  do  that, Add to Jukebox+ won't appear again. You can then  turn the wrongly used folder back to  a media store.
Known Issues
1. flac cue file - awaiting a fix from Realtek
Scraper skin Yadis style
http://www.mede8er.org/skin_pack_downloads/X2_V3_Series/X2_Scraper Skin - Yadis look_V1.zip
Online Jukebox+ Guide
JukeBox Plus Instructions
3. We have added a facility in the GUI to add a folder so you do not require a PC to do this -   Navigate to a Drive or Network Share in the Mede8er Media Library and press the 'Edit' button on the remote and you will see a new function named 'New Folder'  - Use this this make your JukeBox Plus folder
WOL (Wake On LAN)   Setup Menu ---Misc  --- WOL
Select the devices you want X2 to wake up on boot - WOL on X2 boot-up is not always reliable due to the  network not always being ready so X2 will also send the Magic Packets when you enter the Favourite Screen. You can also do a manual WOL in Setup Menu - focus on Device and press 'F1 /Red' button.
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X2. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
Remove any USB drives and /or  Mede2key dongle before performing the upgrade.
