Then go back and do the test I asked before. Use Auto DHCP on your PC and then see what info it gives for the networks DNS server. You can post what you find as before using those images.
Sorry i'm having trouble doing this test,could you explain how go about it.
I did an ipconfig /all in cmd promt and this shows my dns server as 194.132.32.32
which is the one i got from ipredator.
Also shows dhcp enabled =yes and autoconfiguration enabled=yes.
