You may have noticed that the latest mede8er firmware supports fanart.jpg files in your movie folders. YADIS
does grab "fanart.jpg" files when it scrapes your movie info. However "Yadis for Mede8er" does not bring over these fanart files into your movies folders. These fanart files appear as a background when using the media library (see rest of thread for discussion).
From what I understand (see below), Yadis for med8er is meant for jukebox only. But with the way the mede8er works, YADIS is also integrated with the media library view as well. So if you use YADIS to view info sheets in library view (press info button while selecting movie folder) , you might as well grab the fanart file as well so you can see it in the background after entering the movie folder.
When you use the mede8er internal scraper, it downloads fanart files for you and puts them where they need to go. However if you're in this forum, it's likely because you want to use YADIS instead.
I wrote a quick and dirty vba macro in Excel to accomplish this task for myself. However I thought I would share it in case anyone else could benefit from it. Since it's an Excel vba macro, it unfortunately requires Excel 2007 or 2010. I am working on porting it into a compiled Access project so you don't need any external program to run it. For now...those without Excel 2007 or 2010, I'm sorry
Please be warned...I am not a highly experienced programmer. I know vba pretty well...but I mainly just write office macros. I'd rather this be written in some other standalone language, but alas...vba is what I know...and it does work.
It works great on my computer. However I can't guarantee that it will work on yours. If you have a problem with it and want to let me know your error, i
may be able to look into it.
It is very simple to use.
1. run "yadis 2.3" and scrape your movies as usual. I personally use Mede8er profile as I don't really see any benefit to mede8er users when using the dune profile. But you can use either one.
2. run "Yadis for Mede8er" like usual. Now everything is good to go except for the fanart files. There are fanart files in the Yadis workspace data folder, they just need to be brought over into your movie folders.
3. Open up the Excel file. Make sure macros are enabled in your security.
4. Type in your YADIS workspace folder path (or hit the 'choose' button).
5. Type in your Movies root folder path (or hit the 'choose' button).
Defaults have been given for examples only.6. There is a custom tab in the ribbon called, "YADIS Macros" (it should be the first tab in your ribbon). Simply click on the first button to copy your fanart files. If it is successful, it will tell you how many movies/fanart files were processed.
You will notice that there's another button labeled, "Delete playlist.m3u files". This is a completely separate tool that I made for myself. There are probably not too many people who will find it useful unless you store trailer files in your movie folder like myself.
I don't know why, but apparently when you run YADIS, if you have more than one video file in the same movie folder, it creates a completely unnecessary "playlist.m3u" file. Very annoying since I have a movie trailers in the same folder as the movie. So this little tool just deletes the playlist files from each movie folder (if one exists).
Once again, it works great for me...but I stil can't give any guarantees. The copy macro doesn't have any delete commands anywhere in the code, so there's no worries of anything getting deleted by mistake if the program doesn't work.
Please let me know if the link "breaks"...thanks!
https://www.dropbox.com/s/wnbv4ni3zsvd8j5/YADISFanartCopy.xlsm
