Hi
I sometimes transfer movie files from my pc to my mede8erx2 500 which is located some 25 meters away through a wired connection cat5e cable network. My pc adapter is a TP-LINK 1000Mbps pci adapter which then is having internet connection from the modem router (provided by the internet company) the Technicolor TG582n which has 4 port switches 10/100Mbps with performance of 802.11b/802.11g/802.11n.
I Have also a Devolo 500Mbps connected and I can transfer files either through a direct cat5e cable or through the devolo.
Then when I come to transfer a maybe 6Gb movie file from my pc to the mede8er (25mts away) via a cat5e cable or via the devolo 500Mbps on both occasions and exactly the same it will take more then 2 hours and 30 minutes at a transfer speed of 780KB/second. (on the mede8er the UPnp is off and the Nas is on).Is there any solution to improve my transfer speed or any settings that I need to do on my pc, modem router and my mede8er x2 500, or should I buy new equipment to improve this transfer speed cause it is taking ages.
Any HELP or suggestions are much appreciated. THANKS.
