Author Topic: BluRay Player  (Read 27241 times)
Offline Mik3R
BluRay Player
« on: November 06, 2013, 10:44:56 AM »
I was wandering if it's possible to connect an USB external BluRay player to the Mede8er 600/800/1000 to watch BluRay movies...
I dont have one so I didnt test it...
Anyone has this info???
thanks
Re: BluRay Player
« Reply #1 on: November 06, 2013, 03:35:41 PM »
There is no bluray decryption code with bd lite, the only code recent media players (without an optical drive) are allowed to use by bd.org.
Only players with an internal optical  drive (or space for it) will have a licence of the full bd code, the extra cost of which is  passed on to  the user. That code will not play  rips, so such players also need bd lite for those.
Offline Mik3R
Re: BluRay Player
« Reply #2 on: November 06, 2013, 03:54:22 PM »
So... the answer is no? Not possible to attach an USB Bluray player to the Mede8er?
Re: BluRay Player
« Reply #3 on: November 06, 2013, 04:45:22 PM »
Not to play retail  disks. Even self made disks are an issue as the overheads are higher playing such  disks and those who try this  report stutter as a result.
Offline Mik3R
Re: BluRay Player
« Reply #4 on: November 06, 2013, 04:58:17 PM »
Thanks, Jer...
I'm reading the specs of the samsung SE-506AB/TSBD... it says it has AV Connectivity... meaning it can connect to TV's over USB...
System Requirements for using the AV Connectivity Function
• OS: Linux, WinCE, Android Tablet (Honeycomb 3.1 or above with USB Port)
• Device function: Video, photo & music file playing function through a USB interface
• USB port current: 1.4 A or higher
Still doesnt work with Mede8er?
Re: BluRay Player
« Reply #5 on: November 06, 2013, 05:08:00 PM »
These things require a lincence...and sony are in constant battle to try and make it impossible for rip players to have access to the full bd code.  The media players in Smart TV's can't play bd rips, so sony have no issue with letting them play full bd the way you describe.
We don't live in a plug'n'play world where any 2 pieces of kit you like will work together. We actually live in a system builders worlds where only selected compatible kit will  work together.
Offline Mik3R
Re: BluRay Player
« Reply #6 on: November 06, 2013, 05:12:32 PM »
OK, I get you Jer... thanks a lot.
Offline Mik3R
Re: BluRay Player
« Reply #7 on: November 07, 2013, 04:32:35 PM »
Actually I talked today with Samsung guy that told me that It's possible to connect the portable Samsung Bluray Writer to the TV via USB...
Anyone has one and a mede8er to test this???
thanks
Re: BluRay Player
« Reply #8 on: November 07, 2013, 04:36:33 PM »
thanks
What has this  got to  do  with the x3d?  He is confirming that  the TV has the full BD code to  support an  attached bd player.  You keep  assuming that if one device can do  something..every device can.
The Med could only get a licnce to  do  that if they disable all support for playing rips, rips your TV can't play in order to  get it's licence.
« Last Edit: November 07, 2013, 04:41:36 PM by jer1956 »
Offline Mik3R
Re: BluRay Player
« Reply #9 on: November 07, 2013, 04:53:39 PM »
I was assuming the full code was on the Samsung Bluray writer/player and not on the TV cause desktop Bluray players can be connected to any TV and play the Bluray movies.
Offline RobinC
Re: BluRay Player
« Reply #10 on: November 07, 2013, 06:31:23 PM »
That is basically a drive. It doesn't play the discs as such you still need software with a licence to view the content of a disc. Something like PowerDVD on a PC
Offline Mik3R
Re: BluRay Player
« Reply #11 on: November 07, 2013, 06:37:17 PM »
So you're saying the TV has the Bluray license? Sorry but that doesn´t make sense.
Desktop Bluray players has that license, right? Why wont this one have a license if samsung claims that it's AV capable via USB?
Sorry but I'm just not getting it.
Offline RobinC
Re: BluRay Player
« Reply #12 on: November 07, 2013, 07:17:07 PM »
I think it comes bundled with PowerDVD so that's a clue. I think this drive is aimed at people who want to plug it into a laptop or something. On Samsung's website it is billed as a PC peripheral:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/optical-disc-drive/slim-dvd-writer/SE-506AB/TSBD
Looks to me like a plain old optical drive that can read data stored on a blu ray disc.. Like when you get a DVD drive in a PC. That by itself doesn't mean the PC can play DVDs there is normally software required on the PC which has a licence.
Not sure that the AV connectivity it is referring to actually means. It has a USB port that's it
Offline RobinC
Re: BluRay Player
« Reply #13 on: November 07, 2013, 07:22:49 PM »
Just spotted the AV connectivity that it mentions on that page I linked to. I take that to mean that if your TV is capable of playing files from the drive then it can. I take that to me if you put some MP3s or AVIs on a disc then you can play them back directly on the TV if the TV supports that functionality. There is no mention anywhere of things like Dolby TrueHD or DTS HD which I would expect on a product that had a BD licence.
Offline Mik3R
Re: BluRay Player
« Reply #14 on: November 07, 2013, 08:03:30 PM »
Thats what I suspect too... If anyone could test this would be great.
