Author Topic: 3TB External HDD Not Working  (Read 6236 times)
Offline TheVVolf
« on: October 14, 2013, 07:28:30 PM »
I JUST got my Mede8er MED500X2, and I am very happy with it...except that it does want to read my 3TB ext HDD.  :'(
I have tried it NTFS + 1 partition, NTFS + 2 partitions, FAT32 + 2 partitions. No luck...
Please, can anyone give me some tips?
I've read thru a lot of posts, and I haven't found anything that gives a guide on how to format a 3TB ext HDD, only install drives.
If anyone can give me some help, I would be ever grateful.
Re: 3TB External HDD Not Working
« Reply #1 on: October 14, 2013, 07:44:42 PM »
How is it powered, mains or USB?  Does it have embedded security?
« Reply #2 on: October 14, 2013, 08:04:00 PM »
How is it formatted?
MBR or GPT?
Offline TheVVolf
« Reply #3 on: October 15, 2013, 06:41:05 PM »
Thanks for the replies, guys. Please be patient, I'm a bit of a noob with this stuff sometimes.
It is mains powered.
I'm not sure on the formatting... how can I check?
Offline TheVVolf
« Reply #5 on: October 15, 2013, 08:04:02 PM »
Found I still had Acronis on my laptop.
Both partition are Basic GPT FAT32, each about 1.36 TB...
« Reply #6 on: October 15, 2013, 08:08:52 PM »
Multiple partitions is not supported - already tried to created only one NTFS partition on it?
Offline TheVVolf
« Reply #7 on: October 15, 2013, 08:11:33 PM »
I got a 2nd 3TB, identical, that I haven't buggered with at all.
1 Partition, NTFS, Basic GPT... No worky on Mede8er... :'(
« Reply #8 on: October 15, 2013, 08:47:38 PM »
So 2 identical drives - 1 working and the other not working?
Has the one that is not working maybe no disk label name and the other that works has?
With disk label I mean when you connect it to your pc, and right click on the disk, there is a name in the input bar on top.
Offline TheVVolf
« Reply #9 on: October 15, 2013, 09:58:12 PM »
Both are not working...
Both are labelled...
« Reply #10 on: October 16, 2013, 05:32:46 AM »
Strange - what is the brand and type of those disks?
« Reply #11 on: October 16, 2013, 08:37:05 AM »
Your not trying to use the blue port are you?
Offline TheVVolf
« Reply #12 on: October 17, 2013, 10:40:10 AM »
Nope, not using the blue port...I think.. I'm using the one on the side... did try the back too...
The Brand is CipherWave. Not sure of the type, think probably SATA?
« Reply #13 on: October 17, 2013, 03:51:01 PM »
Never heard of that - googling shows that it is from a SA company.
Assume you are living in SA?
Maybe in the near to the Sanji office?
Have you tried to give them a call to discuss this issue?
Offline TheVVolf
« Reply #14 on: October 17, 2013, 10:02:44 PM »
Yes, I'm from Cape Town, South Africa.
I had massive problems dealing with these guys after they stuffed up the deliver of the drive, I order. Resulted in them sending me multiple drives, instead of only one, and the tech support is shocking, so my best hope was here.
