Author Topic: Feedback for - Y2M By Peter Butler V2.0.5 Mod Shizzl Yamj 2.10 r3763 12Oct2013  (Read 83004 times)
Offline biondo_bs
Y2M  can't  work  ....
I follow  all the instruction, download last JAVA update  (jre-7u51-windows-x64.exe)  I'm using Windows 7 ultimate 64 bit ,
and Net-fremwork  4.0
I run Y2M  and when start scanning an error message  appear :
""java" not recognized as internal or external command,
  operable program or batch file "
What is wrong ?  Can someone help me ?
Thank You in advance
Ronny
Offline djhifi
do like me. Buy a XBMC or a popcornhour.
Anything that isn't from the 90's with plain brick jukebox software
Offline jdog23
::::Completely Lost With this, Please Help::::
« Reply #32 on: April 11, 2014, 04:29:12 am »
Okay,so I've been using YAMJ to Med8er for years and all of the sudden it stopped working. I loaded up this newer version and it appears I'm going backwards. At first it pulled up all the titles but would crash as soon as I would click on a title. I've re-installed java 32 and 64 mutiple times. Reinstalled framework. Rebooted system multiple times. Cleaned REG o f YAMJ multiple times. I'm using Windows 7 64bit.
All I get now is this when I run YAMJ. It freezes at this point. Any help would be greatly appreciated.
Yet Another Movie Jukebox 2.10-SNAPSHOT
http://code.google.com/p/moviejukebox/
Copyright (c) 2004-2013 YAMJ Members
This software is licensed under the GNU General Public License v3+
See this page: http://code.google.com/p/moviejukebox/wiki/License
     Revision: r3763
   Build Date: 2013-10-10 16:55:32
 Java Version: 1.7.0_51
Existing jukebox video information will be preserved.
Processing started at Thu Apr 10 21:21:27 PDT 2014
Using properties file ./properties/moviejukebox-default.properties
Using properties file ./moviejukebox.properties
Using properties file ./skins/default/skin.properties
Failed loading file ./skins/default/skin.properties: Please check your configuration. The properties file should be in the classpath.
java.io.FileNotFoundException: .\skins\default\skin.properties (The system cannot find the path specified)
   at java.io.FileInputStream.open(Native Method)
   at java.io.FileInputStream.<init>(Unknown Source)
   at com.moviejukebox.tools.PropertiesUtil.setPropertiesStreamName(PropertiesUtil.java:61)
   at com.moviejukebox.MovieJukebox.main(MovieJukebox.java:245)
Offline hebos
I experienced all mentioned exceptions, but found the solution for all of them.
You don't need to repeat installation process but only perform cleanup.
Cleanup instructions:
1. Remove registry key found on HKCU\Software\YamjToMede8er
2. Remove your jukebox folder
If you perform only one part of the cleanup instruction you will get errors again.
Allways perform both and have only 32 bit java installed (having 64 bit machine).
nenito2k
  • Guest
guys need advice...started using Y2M and like it...it is more reliable that yadis...but has less functions still there is one thing that does bother ME and could not find a solution
every 2-3 days i add a new movie to my FOLDER...so i open up Y2M and click "run yamj"...HOWEVER the software reprocesses ALL my old movie and it takes a LONG TIME again & again....
HOW can i SKIP the old movies and go much faster ???!!  ::) ::)
i unchecked "process all files" BUT Y2M still scans ALL movies !!!!! help !
ps: great work PETER Butler
Offline monkeywash
Just untick the <Process All Titles> box in Process Options and only tick the new movie on the movie list on the left..
Also, in settings, set <recheck.XML> to False under <mjb> to stop periodic rescrapes.
« Last Edit: May 17, 2014, 06:47:20 pm by monkeywash »
nenito2k
  • Guest
will try that :)
nenito2k
  • Guest
@monkeywash
did that...and it seems a little quicker :) BUT still not got "issues"
1- when i add or delete a movie in my drive (F:) and then open Y2M...is there any way for the software to monitor and refresh that folder on startup ? like what "tvrename" does ?
2- when deleting movie in F: and than scanning with y2m....the movie is still there( according to y2m anyway)  ???  ;D that is not normal....
3- why does yamj always rechecks existing videos on some movies....that retakes time...is there anyway to skip existing videos for movies that have already been scanned?
« Last Edit: May 19, 2014, 06:53:52 pm by nenito2k »
Offline monkeywash
@nenito2k
1. As far as I'm aware there's not an automatic refresh in Y2M.
2. You need to check <Delete unused files from the jukebox> on the settings page. To make sure they are being deleted, you can look at the in the YAMJ jukebox directory (<Jukebox location>)
3. By default, YAMJ rechecks 30 days after a movie is first scanned. To disable, in <mjb> on the properties pane, set <recheck days> to 0 and <recheck.XML> to false.
nenito2k
  • Guest
thanx for your time ! will try as soon as i get home !
Offline Buff
Hi Guys,
My About.jpg file txt color is all black fonts how do I get white txt color?
Its very difficult to see the plot text.
Does anyone know how to fix this problem?
CHEERS
nenito2k
  • Guest
WHY do all pictures in the Med8er look SD on the scraper ??? all is OK on PC, but on my TV it looks BAD - very low resolution and colors are like washed out a little....
any ideas ?
Offline jalize
Sorry to say this version does not work for me as hard as I try. I have done all the necessary steps and always give the same error details
Failed to compile stylesheet: 2 errors detected.
Going back to the previous STABLE version. >:(
Offline hdmkv
It would be nice to have a new version of Y2M with the latest YAMJ build. This version of Y2M is almost 9 months old!
Firmware: Always Latest Beta
Networked via CAT5e
Offline sajidassad
hey guys
is there other templates available like there are for yadis
