Author Topic: Synology NEWBIES tutorial for sharing files in network (NFS and SAMBA)  (Read 47333 times)
Offline couto
Here my tips to share  files in your network using  Synology Nas using NFS protocol and samba protocol
NFS
1- go to control panel
2- go to win/mac /nfs
3- serviçe NFS > tick NFS > save
4- go to control panel > shared file
5- choose the file wish to share mine is called videos
6- choose NFS privileges
7- create new rule
8- activate assincrono > put IP ADDRESS  of X3D player or ip adress + * (asterisk) see picture
9- privileges configuration
10- make sure you have read and write permissions if you using jukebox scrapper
done
enjoy
« Last Edit: October 07, 2013, 09:37:22 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline demonrecords
Re: Synology NEWBIES tutorial for sharing files in network
« Reply #1 on: October 07, 2013, 03:42:26 AM »
Good!
You should specify that this is a setup for using NFS instead of SMB.
Why do you keep on watching the porno after you came?
Offline couto
« Reply #2 on: October 07, 2013, 09:27:05 AM »
SAMBA
Samba/SMB is enabled by default on Synology NAS.
A)Log into the diskstation manager and go to "File Sharing-Win/MAC OS"
B)  there you should see "Enable Windows File Service" and if its ticked then SMB is enabled.
« Last Edit: October 07, 2013, 09:35:31 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline hdmkv
Great guide couto.
Firmware: Always Latest Beta
Networked via CAT5e
