Author Topic: Having problems getting the 600x3d to stream via NFS from my DS1812+  (Read 4008 times)
Offline Yochelman
As the title gives away, I can't seem to get my med8er to see the inside of my NFS folders.
It finds the folders after I use probe with my nas ip but that's it.
I need some help, pls
Any tricks or special configurations ?
Sent from my iPad using Tapatalk - now Free
Offline couto
Re: Having problems getting the 600x3d to stream via NFS from my DS1812+
« Reply #1 on: October 06, 2013, 11:56:01 pm »
did you share the file in synology ?
how ?
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
« Reply #2 on: October 07, 2013, 03:14:53 am »
Have you rebooted your mede8er after the NFS probe?
Offline couto
« Reply #3 on: October 07, 2013, 09:29:30 am »
Create a help tutorial for synology users
http://www.mede8erforum.com/index.php/topic,12432.0.html
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
