Author Topic: Newbies tutorial for Mede8er world (600x3d / 800x3d / 1000x3d ) sartup basics  (Read 287103 times)
Offline couto
If you are reading this topic its because you have bought, or going to buy one of the mede8er players available in the market
First and foremost the tutorial only tends to show the basics of the mede8er players, theres more settings and features available to use apart from what is written here....enjoy
Organize your library
the x3d players allow to make a jukebox, a wall of organized movies to quick select and watch the movie from the remote or IOS device with appropiate app.
The x3d makes scan of the movies inside your hard drive, but for that it need to follow one simple rule :
Every movie needs to be in is own individual file, see the example :
1- root folder
2- movies folder  (2D, 3d, dvd, concerts)
3- individual movie folder
4- movie file
See the remote, make sure you are familiar with it, the Menu KEY  in particular
« Last Edit: January 17, 2016, 11:36:15 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline couto
When you bough the X3D , probably it has the lastest firmware, if not follow the instructions below :
go to  mede8erforum
1- product page
2-  firmware download  page
3-  firmware version
4-- link to download firmware
To install the firmware the hdmi cable or video output NEED to be connect to tv or av amplifier
5- power
6-  ethernet connection
7-  hdmi
8- pen usb with ONLY the firmware INSIDE that we previous download
9-to make a clean install of the firmware,  only keep the pen  inserted in X3D NOTHING ELSE, press power button until the mede8er logo show on tv, remove the finger and let the instalation run without turning off the player.
10- when it reach 100% it automaticly reboot
« Last Edit: September 28, 2013, 08:30:44 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
Initial settings
Now that you have a new firmware you probably are stuck in this menu
11- choose language
12- time
13- wired lan setup
14- if you choose random IP Adress move to step 19
15- manual ip configuration
16- choose fix ip address, the submask from your lan, and your  router ip address
17 - choose different  dns ex: google 8.8.8.8 ( the dns is adviced to be different from your ISP provider )
18- save settings - yes
19- go to  settings
20- in audio put trueHD/DTS-HD in case you have receiver that support does audio codecs, otherwise leave AUTO
21-In video put  1080p /23,976 ON + autoframerate ON
22- network go to  NFS option  (if you have one  Nas synology ou QNAP)
optional settings
DLNA - turn on to use X3D has media render
samba process - put on and your X3D is visible in your network
Web remote - to control X3D with browser
23- Put  udp or auto + 32768
24- In misc put  jukebox view ON e autoview ON
« Last Edit: September 28, 2013, 08:32:33 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
We finish the basics settings the X3D is ready to play movies
In case you want to make the jukebox follow the next steps
25- go to media library
26- if you use internal/external hard drives, move to step 29
27-  network (samba ) in case you want to streaming movies from pc or NAS
28- NFS  in case you want to use this  protocol to streaming from pc or NAS
 NETWORK (Samba) EXAMPLE
27-go to  workgroup
27-B this folder is called synlogy is shared by a server  or NAS  in my network, you can do the same with pc, the windows shares folder must be visible in same network, with read and write permissions turned ON.
27-C Put username and password and  choose save to shortcuts, and next time you can access to MY shortcuts folder
If everyting went  accordingly you should able to see your shares folders (pc or NAS) in your X3D menu
29- heres few shares files in network (THIS ARE ROOT FOLDERS ) , in case you using internal or external hard drive you are seeing the same.
30- access files and press menu key , now you can add to favorites or scan jukebox
31- heres another example
« Last Edit: September 28, 2013, 08:34:47 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
Now that you already add movies to favorites lets move on:
32-  go to favorites
33- press MENU key, and  you can scan jukebox  here or like we did in step 30 and 31 (IT WORKS BOTH WAYS)
Manual configuration of jukebox scan ( in case movie cover is wrong )
34- go to  media library
35- go to folder and choose movie individually to change press MENU KEY and press EDIT
36- To change or add new cover manually go to scrape
37 - you will have  selection of one or more movies to choose, pick  the correct one
38- all this settings can be changed, make sure you press SAVE before leave the file
« Last Edit: September 28, 2013, 08:36:03 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
reserved 4
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
reserved 5
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline Zakkie
Nicely done couto!
Offline TitleTown
 As a potential new owner and newbie to media players + streaming…..  Thank you for this guide!
Offline PAFER
Nice
THX for this tutorial
Regards from Spain  ;)
Offline gbaxy
When scanning my movie folder (step 33) mede8er just says 'scanning in progress' then 'no movie information found' How do I solve this? Renaming files/folders?! they are in the format suggested  ???
Offline pitpete
Does this work with OS X Mavericks ???
Offline ouserkak
Thank you for the help. I did the manipulation for "TV SERIES" folder
But I have a .jpg file that create for each episode.
series.name - S01E01 - episode.name.mkv
How to not display it.
Thx
Offline Flying_high
My gut feeling says you're scanning the wrong folder.
Step 32 says: "32- go to favorites". It should be read as: "32- go to favorites and highlight your movies folder". Then go to step 33.
You can lead a horse to water but you can't make it drink.
Offline Skyliner
The last beta (3.0.2) is not working properly with scraper. Had the same problems. Swith to last final and you should not have that problem.
Mede8er model and used firmware version: MED600X3D no Wifi Firmware 3.0.5 Beta
Internal hard disk: No
Type of network: CAT5 / Devolo DLAN/Power-LAN 200 mBit/s (with Wifi module)
Networked devices: PC Windows 7 64bit streaming to Mede8er, LaCie Cinema HD via SMB, FRITZ!Box 6360 Cable
Android device brand and model: Sony Xperia S
Android max screen resolution: 720x1280
Android version: 4.1.2
