Author Topic: 1000 networking died  (Read 2260 times)
Offline Thrang
« on: September 24, 2013, 12:54:19 AM »
No changes to my 1000, had been running 3.00 for a while - went to play something today, and while the network status lights are active, there is no networking functioning on the mede8er - wired or wireless, manual or DHCP. Cannot see local or internet resources. Tried har powering down, and did two 3.01 emergency installs to try and bring it back, but no change.
Changed network wire and ports on switch to known working entities, no change.
Any ideas, or how does this get swapped out...?
Re: 1000 networking died
« Reply #1 on: September 24, 2013, 03:12:52 AM »
Have you checked under netwerk info menu?
Does your unit get an IP?
Are you able to ping it from a pc?
Offline momo2013
« Reply #2 on: September 24, 2013, 06:13:24 AM »
Sometimes the rooter need to be restarted or reseted to work fine.
Try this and it should work fine.
« Reply #3 on: September 24, 2013, 07:06:01 PM »
Issue resolved after Thrang did a Restore Default in Setup Menu
