Author Topic: V3.0.1 -16Sep2013 Release for MED1000X3D - MED800X3D - MED600X3D  (Read 71491 times)
  • Helpful Contribution Status: +105/-27
We urge you to firstly read the V3 Specific User Manual before just making posts about things not working correctly.
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc
Win7,8,8.1 users - Safe Removal is incompatible with the linux NTFS code. Instead use Utility to Eject the Mede8er (or shared external USB drive) - USB Disk Ejector http://quickandeasysoftware.net/software/usb-disk-ejector
Vanishing files and un-mountable partitions can occur as  a result of using Safe Removal. Those should get fixed by using slave mode, running chkdsk and removing the player using the tool linked above.
ChangeLog V3.0.1 - 16 Sept2013
1. Dev - Subtitle Delete from Gui - In Movie Play open Subtitle screen and focus on the Subtitle you want to Delete and press the 'Edit' Button
2. Dev - Support for TV Series 'Specials'  - Make a new folder called 'Specials' on the same level as the Season folders.
Episode naming
Game of Thrones - S00E01 - Inside Game of Thrones
Game of Thrones - 0x01 - Inside Game of Thrones
Check 'Online Move Scraper User Guide' for more info
3. Fix: TV Series: when the 'episodeplot' is empty in the scraped xml file, the plot content will missed.
4. Fix: TV Series: normal background (not series background) was displayed after full screen play.
5. Fix: TV Series: Movie and Music View TV Series Thumbnails not vertically centered.
6. Fix: TV Series: In TV Series press BLUE button to switch to Favourites, then go back to media library, tv series background will continue loaded.
7. Fix: TV Series Edit :  year/runtime/rating/genre not editable
8. Fix: TV Series Edit: Slow Navigation when moving Left/Right Nav buttons
9. Fix: xml node 'MainFolderTitle' not changing the colour of the Top Text
10. Fix: String Table: some Korean & French & German strings
11. Dev: String Table: POLISH string updated.
12. Fix: subtitle:  Set 'Match Audio with OSD' in Setup Menu – Set GUI Language to Korean – By default the Korean Subtitles do not show.
13. Fix: Subtitle: set GUI Language to CROATIAN, default CROATIAN subtitle doesn't show.
14. Fix: Subtitle Search – GUI Language Set to English USA – Subtitle Search and X3D crashes.
15. Fix: Subtitle Search - Greek not working.
16. Fix: Subtitle Search: some language multi ISO639-2 codes and first code is matches the subtitle then it will use this language to search and result will be a fail.
17. Fix: Subtitle: some language search will cause system crashes.
18. Fix: Sometimes the Plot text does not update when changing the Focus on Thumbnails
19. Fix: Sometimes cover.jpg is not refreshed in Movie Edit Page when you change cover.jpg.
20. Fix: Mask from Movie scan folder called 'Sample,Screens'
21. Fix: samba NAS: If HDD Name has a space then it does not work on Samba NAS,
22. Dev: '0 movie added' and 'xxx movies added' translated by string table.
23. Dev: Music Playback:  when set repeat off, It should play all tracks in folder and then 'Stop'.
24. Fix: IPTV: '#EXTINF:-1,D8', the name 'D8' isn't displayed
STEP1    IF YOU ALREADY INSTALLED V2 YOU CAN SKIP STEP1
STEP2
Install V3.0.1- 16Sept2013
http://www.mede8er.org/Firmware_Final/MED1000X3D/X3D_Series_V3.0.1_16Sept2013.zip
Alternate Download
http://www.mede8er.com/Firmware/X3D_Series/X3D_Series_V3.0.1_16Sept2013.zip
Note: After a Firmware Update you need to add the JukeBox+ folder back to Favourites then Press Menu button and select ‘Aggregate JukeBox’ and then it should be exactly the way it was prior to the update.
Yadis Look Movie Scraper Skin
http://www.mede8er.org/skin_pack_downloads/X3/Scraper_Skin_Yadis_look.zip
Yadis Look Movie Scraper Skin2
http://www.mede8er.org/skin_pack_downloads/X3/Scraper_Skin_Yadis_look2.zip
Default Movie Scraper Skin Sample
http://www.mede8er.org/artwork/temp/2013/Mede8er_v3_default_movie_scraper.jpg
Yadis Look Movie Scraper Skin Sample
http://www.mede8er.org/artwork/temp/2013/Mede8er_v3_Yadis_Look_movie_scraper_skin.jpg
JukeBox+ Online Guide
ChangeLog V3.0.0 - 23 Aug2013
1. new - Movie Scraper App
2. new - TV Series Scraper App
3, new - Built in Subtitle Downloader
4. new - IP Stream App
5. new - WOL (Wake on LAN)
6. new - HTML5 Browser
7. Fixed - Arabic srt Subtitles
8. Fixed - MP3 UFT8 embedded text
9. Fixed . Fixed IP of Wireless not working
9. Dev - Nav Up / Down moves srt subtiles up/down
10. Dev - Added support for external subtitle language naming
11. Dev: added grey color for subtitle
11. General bug fixes
Known Bugs:
1. Dont use Subtitle Search if Language is set to ENG (USA)
2. Greek Subtitle Search not working
3. Edit Movie image and re-edit without exiting the Folder and the images in edit mode is not updated
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
« Last Edit: January 13, 2014, 09:02:26 pm by Maasbommel »
Re: V3.0.1 -16Sep2013 Release for MED1000X3D - MED800X3D - MED600X3D -Latest
« Reply #1 on: September 26, 2013, 08:47:01 am »
Known Issues
1) The Scrapers are very intensive users of DNS and fail if the DNS server in the LAN setup is not adequate. You  should then try using settings other than 127.0.0.1, such as the Router IP (same as gateway) or free DNS such  as 8,8,8,8.  The latter may have an adverse affect on local DNS..so sharing may  then stop  working.  So "some" users may  find they need to  change the setting purely for scraping.
« Last Edit: September 26, 2013, 09:03:53 am by jer1956 »
