Author Topic: V3.0.0 -23Aug2013 for MED1000X3D - MED800X3D - MED600X3D  (Read 109337 times)
  • Helpful Contribution Status: +94/-20
« on: August 23, 2013, 01:25:13 pm »
v3 is finally ready  ;D
As usual Its been a long hard road from the time we started V3 in a small User Group back in early July 2013. I would like to thank our brilliant engineer Frank for his superb work on this release. Also a great big thank you to Maasbommel and Jer1956 as without their assistance V3 could not have happened. To all the Mede8er Beta testers - We thank you ;D
We urge you to firstly read the V3 Specific User Manual before just making posts about things not working correctly.
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc
Win8 users - Use Utility to Eject the Mede8er - USB Disk Ejector http://quickandeasysoftware.net/software/usb-disk-ejector
STEP1    IF YOU ALREADY INSTALLED V2 YOU CAN SKIP STEP1
STEP2
Install V3.0.0 - 23 Aug2013
http://www.mede8er.org/Firmware_Final/MED1000X3D/X3D_Series_V3.0.0_23Aug2013.zip
Alternate Download
www.mede8er.com/Firmware/X3D_Series/X3D_Series_V3.0.0_23Aug2013.zip
Note: After a Firmware Update you need to add the JukeBox+ folder back to Favourites then Press Menu button and select ‘Aggregate JukeBox’ and then it should be exactly the way it was prior to the update.
http://www.mede8er.org/artwork/temp/2013/V3_X3D_22August2013_v1.pdf
Yadis Look Movie Scraper Skin
http://www.mede8er.org/skin_pack_downloads/X3/Scraper_Skin_Yadis_look.zip
Yadis Look Movie Scraper Skin2
http://www.mede8er.org/skin_pack_downloads/X3/Scraper_Skin_Yadis_look2.zip
Default Movie Scraper Skin Sample
http://www.mede8er.org/artwork/temp/2013/Mede8er_v3_default_movie_scraper.jpg
Yadis Look Movie Scraper Skin Sample
http://www.mede8er.org/artwork/temp/2013/Mede8er_v3_Yadis_Look_movie_scraper_skin.jpg
JukeBox+ Online Guide
ChangeLog V3.0.0 - 23 Aug2013
1. new - Movie Scraper App
2. new - TV Series Scraper App
3, new - Built in Subtitle Downloader
4. new - IP Stream App
5. new - WOL (Wake on LAN)
6. new - HTML5 Browser
7. Fixed - Arabic srt Subtitles
8. Fixed - MP3 UFT8 embedded text
9. Fixed . Fixed IP of Wireless not working
9. Dev - Nav Up / Down moves srt subtiles up/down
10. Dev - Added support for external subtitle language naming
11. Dev: added grey color for subtitle
11. General bug fixes
Known Bugs:
1. Dont use Subtitle Search if Language is set to ENG (USA)
2. Greek Subtitle Search not working
3. Edit Movie image and re-edit without exiting the Folder and the images in edit mode is not updated
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
« Last Edit: December 15, 2013, 06:44:00 pm by Mede8er1 »
Another version of Yadis Look Movie Scraper Skin
