Author Topic: Cannot delete a file + very slow boot up - FIXED  (Read 3007 times)
Offline Admnistrator
« on: February 05, 2010, 12:01:22 PM »
I am a bit stuck, I use WiFi to manage my files.
Some girls in my house switched-off the box while I was copying a file over.
Then I could not delete the file or folder.
-tried via RC/TV, delete process just hangs. Box must be unplugged.
-tried via WiFi+Windows Explorer, again just hangs. Box must be unplugged.
-tried via WiFi+FTP, again just hangs. Box must be unplugged.
-tried via USB, initially refused (file locked, etc) - then suddenly allowed me to delete it.
Then a "recycler" folder was created, now this cannot be deleted or emptied.
FYI: The permissions on the file & folder are correct, according to FTP.
After I had this issue, unplugged boot time now takes about 4-5 minutes.
I know it could be the HDD, but it reads all files instantly, transferred 6Gb today, no [other] problems whatsoverer.
Any help or pointers appreciated.
« Last Edit: February 07, 2010, 02:33:49 PM by Admnistrator »
V3.05
MED500X with 1Tb HDD
100Mbit Network using WiFi (N)
Networkshare via WinXP
Connected via HDMI LCD
AUDIO : Samsung HT-TX35 (HDMI)
LCD TV: LE46A-656A
Offline Sparkie84
Re: Cannot delete a file + very slow boot up
« Reply #1 on: February 05, 2010, 06:45:17 PM »
Bit of  long shot, but try removing the HDD, adding it in your PC as an extra drive. Try deleting in Windows (But think I can guess it wont).
Then try booting up in safe mode with Command screen and try removing the offending dir within DOS emulation screen.
Mede8er Ver 2.0.2  (1 Upgrade from 1.2.1)
1.5TB Samsung HD154UI EcoGreen SATA, Formatted by Mede8er Ver 1.2.1
100bt LAN  to Vista Dell 2.8Ghz Duocore PC (4G Ram) via Thompson ST330 Router
RCA Output to Scart on Standard 14 TV -  (Temporary Arrangement)
« Reply #2 on: February 05, 2010, 11:18:57 PM »
I've copied 500Gb off & reformatted the hdd  (again as FAT32).
Just got to reformat the hdd via firmware, then I can copy the files back.
Appears to have been file corruption: I just wanted to make sure I didn't lose some 500Gb of data!
Note to anyone else using WiFi, make sure no-one will switch the unit off while you are copying onto it!
I will add "Fixed" to the title, if this also fixes the boot-up issue.
-it did!
« Last Edit: February 07, 2010, 02:34:24 PM by Admnistrator »
V3.05
LCD TV: LE46A-656A
Offline Insomniac
  • Moder8or
  • B8a Tester
« Reply #3 on: February 06, 2010, 07:26:56 AM »
You took drastic measures which worked for you, but for future reference and for others that get a corrupt file due to a failed copy, you shouldn't need to format.
To repair those errors that may occur during an interrupted copy, proceed as follows:
  o Plug the unit into your PC via USB
  o Go to START > RUN > CMD > OK
  o Navigate to the drive letter of the Mede8er, e.g. type in F:
  o Type in CHKDSK /F from the Mede8er drive letter prompt.
You can also do this from the Windows GUI for those less comfortable with DOS line command (this example is for XP but it should be relatively similar for other Windows systems):
  o Go to START > RUN > EXPLORER
  o Right-click on the Mede8er drive letter > click on Properties
  o Click on the Tools tab
  o Click on Check Now
  o Tick Automatically fix file system errors and Start
  o Wait for the process to finish and the errors should be corrected...
