Author Topic: Looking for BetaTesters for the X3D Built in Movie Scraper  (Read 43174 times)
Re: Looking for BetaTesters for the X3D Built in Movie Scraper
« Reply #75 on: July 15, 2013, 08:16:31 PM »
I am going to get the Med1000x3D this week. Does this new movie scrapper build the jukebox without the need for a computer ?  I have a Mac
Would be great to give it a trail,
Thanks,
Mark.
Yes. It is capable to scrape movie covers and backdrops without the need of a pc.
I have added you and all the ones above you ;-)
Offline Skyliner
« Reply #76 on: July 15, 2013, 09:40:19 PM »
Hi Maasbommel, please add me as well since I am really looking forward to that solution. I am using a MED600X3D.
Which languages with regard to tag information/scraping content are supported?
Mede8er model and used firmware version: MED600X3D no Wifi Firmware 3.0.5 Beta
Internal hard disk: No
Type of network: CAT5 / Devolo DLAN/Power-LAN 200 mBit/s (with Wifi module)
Networked devices: PC Windows 7 64bit streaming to Mede8er, LaCie Cinema HD via SMB, FRITZ!Box 6360 Cable
Android device brand and model: Sony Xperia S
Android max screen resolution: 720x1280
Android version: 4.1.2
« Reply #77 on: July 15, 2013, 09:44:13 PM »
I have added you to the closed test board.
Regarding language supported - it will first take the language that it set for the gui.
If information is not avail in that language on the scaper site - it will fall back to default English.
Offline nkhan
« Reply #78 on: July 15, 2013, 10:51:05 PM »
Can I join too please
Offline jmcr100
« Reply #79 on: July 16, 2013, 05:47:43 AM »
I have a 600X3D and would love to be added to the group  :)
Offline kevin356
« Reply #80 on: July 16, 2013, 07:08:33 AM »
I have a 600X3D, can you also add me ?
« Reply #81 on: July 16, 2013, 12:04:32 PM »
Previous 3 posters added to  test group.
Offline koburg
  • B8a Tester - X3D NET API
« Reply #82 on: July 16, 2013, 12:53:55 PM »
im also interreseted in testing if there room for more.
regards allan
Offline CustOM_20
« Reply #83 on: July 16, 2013, 04:47:22 PM »
Please add me to, would love to test it out! :)
Offline angrek
« Reply #84 on: July 16, 2013, 06:47:23 PM »
Count me in .... MED600X3D with external USB drive 1Tb
Angrek
« Reply #85 on: July 16, 2013, 07:33:55 PM »
You are all 3 added now.
« Reply #86 on: July 16, 2013, 08:17:40 PM »
Application for closed beta test group is closed now.
We have enough testers for the moment.
