Author Topic: Common Problems  (Read 16735 times)
  • Helpful Contribution Status: +202/-55
Common Problems
« on: July 04, 2013, 11:45:52 AM »
Skin spoilt by Blue Text:-
Setup ---> MISC ----> Home Page Text  Set to 'Off'
Offline gmp8er
Re: Common Problems
« Reply #1 on: October 17, 2013, 10:53:14 AM »
I have tried several skins myself.
The skins I tried (Localization Dutch, That Theme) caused the "screen size" option in the setup menu, to no longer function correct on my MED600X3D. I had to revert to the default skin for this option to function again.
Any ideas?
Offline gmp8er
Re: Common Problems
« Reply #2 on: October 18, 2013, 01:41:20 AM »
Any ideas?
That is "screen calibration"
Offline Monaco
Re: Common Problems
« Reply #3 on: January 12, 2014, 09:56:38 AM »
hi , am have 3.2 finrare , am I want to change skin , problem am no faund skin option ( menu ) help my ? ALL MUNIU CHAKED NO SKIN OPTION HELP ? SORTED Thank you very much.
« Last Edit: January 12, 2014, 07:17:36 PM by Monaco »
