Author Topic: Can't access X3D folder  (Read 8142 times)
Offline tommytinkroom
  • The Dirty Boys
« on: June 22, 2013, 05:19:13 pm »
Hi,When i click the X3D folder on my pc i'm prompted to put in a
user name and password for network login which i've never had.
I've checked network and sharing settings and i can't see anything wrong.
Computer type Laptop
Computer Manufacturer Samsung NP300E5A-A02DX
OS Windows 7 home premium 64bit sp1
MED1000X3D Version 3.0.2 WD Red - 2TB Desktop SATA Hard Drive
Samsung 51" E6500 Series 6 Smart Plasma TV
Sony STR-DN1040 hdmi to plasma
Pioneer BDP-450
Speakers Tannoy V4/VC/V1 Subwoofer Wharfedale 150
Sky HD
Logitech Harmony 700
Re: Can't access X3D folder
« Reply #1 on: June 22, 2013, 05:37:07 pm »
  • The Dirty Boys
« Reply #2 on: June 22, 2013, 06:26:32 pm »
Had a fiddle about with the Winshare manager for but did'nt get anywhere.
I can see everything on my pc from the X3D and stream it and copy it to the
internal hard drive.
But when i'm on my pc and i try to access the media on my X3D hard drive i'm
locked out and asked for a username and password,this has only just happened
and prior to this there was no problem.Here's a screenshot of what i get when i try
to access the folder.
Pioneer BDP-450
Sky HD
« Reply #3 on: June 22, 2013, 07:12:46 pm »
Do you mean  via  a previous shortcut or via Network Discovery?
  • The Dirty Boys
« Reply #4 on: June 22, 2013, 07:27:00 pm »
Network Discovery i think.Also when on the X3D and i try to open the X3D
folder this also asks me for a username and password.
Pioneer BDP-450
Sky HD
« Reply #5 on: June 22, 2013, 07:33:31 pm »
check if you have turned on Samba Security by accident in the X3d setup.
  • The Dirty Boys
« Reply #6 on: June 22, 2013, 07:49:06 pm »
Both Samba security and processes were turned on,but i think they always have been.
So i turned them off,then checked the pc and the X3D folder has disappeared now from
the left hand pane.
This is were it was before.
Pioneer BDP-450
Sky HD
  • The Dirty Boys
« Reply #7 on: June 22, 2013, 07:58:09 pm »
Just tried putting Samba process back on and left security off and it's fixed it.
Thanks for pointing me in the right direction. :)
Pioneer BDP-450
Sky HD
« Reply #8 on: June 22, 2013, 08:03:50 pm »
Samba security had stopped working in the last few beta's so if you had been turning it on it would have had no effect. It was fixed for the release version.
  • The Dirty Boys
« Reply #9 on: June 22, 2013, 08:26:25 pm »
Thanks for the info jer ;)
Pioneer BDP-450
Sky HD
