Author Topic: MED400X2S - DuneX to Mede8er Series  (Read 9006 times)
Offline Vikt1993
« on: May 26, 2013, 09:42:53 PM »
DuneX2Mede8er works great with my movies, the Jukebox-view is magnificent when I browse through my movies, but when I try to export my TV Series to my MED400X2S, there appear to be a few bugs in the system, I guess. For example, when I try to watch to an episode of Wilfred, the synopsis of Suits appears, and with other series I have the same problem.
I thought I might need to name every season of each series with the name of the series, like Wilfred Season 1. Do I have to do this or is there another option to let duneX work properly with my series?
Thanks!
Re: MED400X2S - DuneX to Mede8er Series
« Reply #1 on: May 27, 2013, 08:55:10 AM »
If you have multiple episodes in one folder then that is what  you will  end up with,  as that is not supported by the MED.  Not all Dune modes are supported.  Currently this is only supported via the Tv Wall...which isn't a jukebox.  Check out TV Renamer.
http://www.mede8erforum.com/index.php/board,149.0.html
Offline Vikt1993
« Reply #2 on: May 27, 2013, 09:27:53 AM »
thanks man! I'm a mac user, so is there an application for mac that does the same job?
