Author Topic: MED800X3D  (Read 48008 times)
Offline KoolKiwi
Re: MED800X3D
« Reply #60 on: November 21, 2013, 06:17:08 PM »
The 800 has a fan which  didn't shut down using Net Api "standby"..so that command has to be ignored or else the fan  would burn out.
Thanks.  But interesting.  Does that mean that "Discrete Off" is still in fact drawing significant power on the 600 & 1000 (to still require the fan to be powered-on, if supported on the 800)?
So for 800 can you still use the Apsolute iPad App, but you would need to first turn on via the IR remote?
Re: MED800X3D
« Reply #61 on: November 21, 2013, 07:18:12 PM »
The 1000 and 600 are fanless.  Net api  stanby has to keep  the CPU running  and cool to process net commands.
Even the 1000 and 600 have to  be powered on "first" without net api.  They are then put into Net Api standby via a Net api client.
Offline tonmeno
Re: MED800X3D
« Reply #62 on: November 11, 2015, 02:40:27 PM »
MED800X3D
HELP HELP !  :-\
Good morning, I bought one of your products on INTERNET SHOP  but
You have big problems with the wireless configuration, you can have a mini guide in Italian?
It also goes well in English if you have a step by step.
please post me a link or manual to tonmeno@hotmail.com
Thank you and regard
Andrea ( Italy )
