Author Topic: MED800X3D  (Read 49609 times)
Re: MED800X3D
« Reply #30 on: May 29, 2013, 07:42:31 PM »
This is going of topic......
Offline peppi1986
Re: MED800X3D
« Reply #31 on: May 30, 2013, 05:16:08 PM »
knows anyone how loud is the fan ?
Re: MED800X3D
« Reply #32 on: May 30, 2013, 07:06:21 PM »
Med800x3d fan is very quiet as we use special fan mounts and the fan has some electronic control that turns down the rpm about 30 sec after boot up.
« Last Edit: May 30, 2013, 07:15:17 PM by Mede8er1 »
Offline peppi1986
Re: MED800X3D
« Reply #33 on: May 30, 2013, 09:31:34 PM »
thx mede8er1
i hope a reseller in germeny has the 800er in the next days
Offline Skyliner
Re: MED800X3D
« Reply #34 on: May 31, 2013, 07:05:44 AM »
The 500x2 case is not plastic!  It's "bent" steel like the 600.   I'm pointing out that a lot effort of effort went in to making the more substantial "cast"  alumimium case of the 1000 fanless by making the huge, heavy case a heatsink.  The demand for a fansless disk hosting device was one reason behind that design. Otherwise the hot 1186 chip and a hard drive will need a fan.
Good morning Jer,
that's nice to know since it is not mentioned explicitely on the website.
The chipset is the same with the RTD1186 like in the X6003D, right? Then it has a Sony Pro Duo Card Slot - who has this?
This seems to be a cooperation between Sanji & Sony like the function of BD-lite?
The facelift is cool and together with the price and support a real alternative to the Himedia 900/910b now.
Are 2,5 and 3,5" internal hard drives supported?
Mede8er model and used firmware version: MED600X3D no Wifi Firmware 3.0.5 Beta
Internal hard disk: No
Type of network: CAT5 / Devolo DLAN/Power-LAN 200 mBit/s (with Wifi module)
Networked devices: PC Windows 7 64bit streaming to Mede8er, LaCie Cinema HD via SMB, FRITZ!Box 6360 Cable
Android device brand and model: Sony Xperia S
Android max screen resolution: 720x1280
Android version: 4.1.2
Re: MED800X3D
« Reply #35 on: May 31, 2013, 04:06:07 PM »
Good morning Jer,
See: http://www.mede8er.com/mede8er_product_med800x3d.html
and http://www.mede8er.com/mede8er_product_matrix.html
3.5 inch SATA slot which means that a 2.5 inch will fit with a conversion bracket and with a conversion sata connector.
Offline Skyliner
Re: MED800X3D
« Reply #36 on: May 31, 2013, 04:50:55 PM »
Thanks Maasbommel, so there ist no reason for a change wehen already having the 600X3D :)
What is menat by " Discreet 'Off' NET API"?
Re: MED800X3D
« Reply #37 on: May 31, 2013, 06:30:08 PM »
This is a mode that puts the player into sleep but keeps network up to respond to the net api command, so a tablet app can switch it on again.
Offline Skyliner
Re: MED800X3D
« Reply #38 on: May 31, 2013, 07:18:58 PM »
Thank you Bommel, this is an aspect I worry about with my 600X3D. With every PC and MED restart the Samba network connection ist lost which means I cannot find the MED as network drive unless I did not switch Samba mode off and on again??
Re: Re: Re: MED800X3D
« Reply #39 on: May 31, 2013, 08:49:24 PM »
Do you use app from Apsolute on an ipad?  That is the only that uses this.
Not the normal mede8er remote.
Offline Skyliner
Re: MED800X3D
« Reply #40 on: June 01, 2013, 08:25:53 AM »
I do not have an Ipad. I just thought when the MED is online it can be found directly in the workgroup of WIn devices.
But Samba is set off every time it seems when the MED is set off.
Re: MED800X3D
« Reply #41 on: June 01, 2013, 09:07:18 AM »
You must have some specific network configuration issue.
Suggest to check the tip section in the network part of the board:
http://www.mede8erforum.com/index.php/board,53.0.html
This is a generic 800X3D topic and your questions are going of topic, please post in the network section to post issues about network issues.
Offline das961
Re: MED800X3D
« Reply #42 on: June 09, 2013, 07:28:35 PM »
When the MED800X3D was announced, I was very interested.  It seemed like what I was looking for.  Yesterday I contacted Media Concepts and asked when it would start shipping and what the price would be.  Their response was:
"Currently, there is no plan to carry the med800X3D.
Regard,
MediaConcept"
Has anyone purchased the 800 yet?  If so how has the performance been so far.  Is there a way to get this in the US since MediaConcept isn't going to carry it?
Offline Juan-Lewis
Re: MED800X3D
« Reply #43 on: July 03, 2013, 05:40:26 PM »
USB 3.0 port is not verry fast  >:(
800X3D & 600X3D from France....
Re: MED800X3D
« Reply #44 on: July 03, 2013, 07:51:26 PM »
What speed do you get?
