Author Topic: MED800X3D  (Read 48010 times)
gsf600y
  • Guest
MED800X3D
« on: May 21, 2013, 08:55:06 PM »
Hello,
I see the new 800 has been announced :) very nice.
I was just comparing the specs with the 600 model, and aside from the obvious internal HDD, was wondering what else was different?
I see there's support for a single USB 3.0 slave, and "Co-Ax Digital" output.
Anything else different?
And whats different when compared to the 1000, apart from the styling?  I much prefer the style of the 600 and 800 over the 1000.
« Last Edit: May 21, 2013, 09:01:31 PM by gsf600y »
Offline inikad
Re: MED800X3D
« Reply #1 on: May 21, 2013, 09:58:32 PM »
So am I. I'm really curious to know what are the differences between the 800 and the 1000.
« Last Edit: May 21, 2013, 10:27:57 PM by inikad »
Offline crussader
Re: MED800X3D
« Reply #2 on: May 21, 2013, 09:59:30 PM »
I should have known. :( The features of the 1000 with the form factor of the 600. This is wanted when I purchased my 600 a month ago. I don't suppose there will be a trade-in program?
Offline gizmo69
Re: MED800X3D
« Reply #3 on: May 22, 2013, 12:40:26 AM »
When will MED800X3D be available to buy?
Offline inikad
Re: MED800X3D
« Reply #4 on: May 22, 2013, 12:48:28 AM »
MED800X3D will be available in Europe from 1 June 2013. Don't know for the other areas.
Offline HomerJau
Re: MED800X3D
« Reply #5 on: May 22, 2013, 04:02:59 AM »
They look to have very similar specs, the 800 has coax output and only one USB input. Also has a conventional case as opposed to the 1000 'rugby ball' oval shape. Uses same firmware.
If they were both available a couple months back then I would have gone for the 800 due to its front controls in my cabinet.
Obviously there must be a need for coax output but surely most users only need HDMI? Maybe there's a place for a model with HDMI output only, no component video and no optical/coax digital audio output and no analog audio output. This would reduce manufacturing costs a bit I would assume, meaning lower cost to users.
Offline esp3tek
Re: MED800X3D
« Reply #6 on: May 22, 2013, 09:18:34 AM »
Seems to have USB 3.0 Host ports (has two)
Fast USB3.0 Port
Re: MED800X3D
« Reply #7 on: May 22, 2013, 09:27:01 AM »
Only the blue port is usb 3.0, and that's for slave mode.
Offline esp3tek
Re: MED800X3D
« Reply #8 on: May 22, 2013, 11:02:03 AM »
Bad new  :(
Offline funkycochise
Re: MED800X3D
« Reply #9 on: May 22, 2013, 11:03:50 AM »
Bad new  :(
so hardware seems to be the same as 1000X3
One question that stay unknown, is the price also the same ?
edit : seen the price : even cheaper than 1000X3, a real bargain imho.
Offline Woops
Re: MED800X3D
« Reply #10 on: May 22, 2013, 09:03:54 PM »
Anyone who knows what it takes to remove / insert the hd?
Any screwdrivers involved or is it more like hot swapping with no faffing about with tools or anything?
Offline francoisZA
Re: MED800X3D
« Reply #11 on: May 22, 2013, 09:25:15 PM »
Looks like the 500 series case, so yes, screws involved.
iPhone iOS 6.1.3 using Tapatalk
Zone 1: All HDMI to NAD
MED1000X3D 0.25TB 2.5"
PCH C-200 0.25TB 2.5" +BDRW
HTPC 4x2TB RAID5 +2x3TB + DAS 4x2TB RAID5 on USB3 + BDRW Win7 HaneWin NFS
SMC WGBR-14N2 Gbit Router + D-Link 2500U ADSL All on Cat6
NAD T765 HD2+C272+C245BEE
LG 55" FHD LED
Zone 2: HDMI to LCD
MED500X 1TB on Cat6 WDLivewire
LG 42" FHD LCD
Zone 3: HDMI to LCD
PCH A-210 0.5TB on Cat6 WDLivewire
Samsung 32" LCD
Offline geezerpl
Re: MED800X3D
« Reply #12 on: May 27, 2013, 02:57:56 PM »
Now there is a reason why we still don't have FW 2.0 for MED600X3D
Bearing in mind the number of beta releases it looks like EOL soon for the 600X3D as they will surely re-shift developers to a new toy.
Same story as with other players I used to own - KISS DP1600, eGREAT (3 models), Popbox V8.
(Removed by mod. Saying what you would buy instead is not within the forum rules. That's basically SPAM for a competing product)
« Last Edit: May 27, 2013, 03:21:51 PM by jer1956 »
Re: MED800X3D
« Reply #13 on: May 27, 2013, 03:07:58 PM »
Perhaps you should understand the product range a little better.  All X3D models use the same firmware...and the software engineers aren't involved the design of cases so it has been no destraction to  them.
If you have kept track of the Public Betas you  will have seen the on going progress being made towards a new firmware for ALL x3d models. Many are already enjoying those improvements because they don't feel limited to only using Release Versions.
« Last Edit: May 27, 2013, 03:42:12 PM by jer1956 »
Offline Skyliner
Re: MED800X3D
« Reply #14 on: May 29, 2013, 04:25:04 PM »
The new 800X3D looks better to me on first sight but what is the box material like?
Besides that it looks to have a fan which is a no go for me. Is this true?
Mede8er model and used firmware version: MED600X3D no Wifi Firmware 3.0.5 Beta
Internal hard disk: No
Type of network: CAT5 / Devolo DLAN/Power-LAN 200 mBit/s (with Wifi module)
Networked devices: PC Windows 7 64bit streaming to Mede8er, LaCie Cinema HD via SMB, FRITZ!Box 6360 Cable
Android device brand and model: Sony Xperia S
Android max screen resolution: 720x1280
Android version: 4.1.2
