Author Topic: Difference between the profiles "Mede8er" or "Dune"  (Read 4312 times)
Offline Deckard2019
« on: May 11, 2013, 09:31:31 pm »
Hi.
Is there any difference between the profiles "Mede8er" or "Dune" under the general setup tab in yaDIS 2.2?
Offline Mr Eric
Re: Difference between the profiles "Mede8er" or "Dune"
« Reply #1 on: May 12, 2013, 01:30:00 pm »
Mede8er profile just creates a simple backdrop that your mede8er will read in simple browsing mode. The dune profile is, obviously, made for dune player and can be used with yadis2mede8er to add extra layer of info as well as be used as "aggregated jukebox".
Yadis beta team member
Offline mikek
« Reply #2 on: March 10, 2015, 10:49:29 pm »
I cannot see a difference between using Dune or Mede8er profile.  I have see you saying that you can add an extra layer of info, but I don't know what that means.
The only difference I have seen is that the dune profile will create "background.jpg" and "dune_folder.txt" files.
Can someone explain the difference and how to implement them?
Thanks.
