Pages: 1 ... 3 4 [5] 6 7 ... 26   Go Down
Author Topic: YAMJ to Mede8er Beta pre-release  (Read 80993 times)
MarioB
« Reply #60 on: February 04, 2010, 08:46:11 am »
@ auren
Try to map network drive from your NAS...
@ButlerPeter
I have tried Y2M on different machine with 1280x1024 resolution, and the results are the same. The about.jpg have scroll bars like in my previous attachment....
Administr8or
« Reply #61 on: February 04, 2010, 09:05:38 am »
Hi MarioB
I tried your skin. Very nice!
If you change the Height to 727 as per attached it takes away the scroll bars. For ref my screen res is 1680 x 1050
about.jpg sample
http://www.mede8er.org/artwork/temp/without_a_paddle.jpg
« Last Edit: February 04, 2010, 01:52:06 pm by Mede8er1 » Logged
Shamus
« Reply #62 on: February 04, 2010, 01:47:06 pm »
Hi MarioB,
nice skin!!
Only thing is I would like to increase the font size, is there any easy way for me to do that. I take it I would have to mod one of the xsl files but I don't know exactly which one or what setting to change.
I had to change the height to 758 to get rid of the scroll bars using a screen resolution of 1920 x 1080 on my monitor.
Cheers
Shamus
Mede8er FW 4.0
Hdd Seagate 1.5 Tb
Network wired lan Netgear 8 port 10/100 hub
TV Sony Bravia KLV40V550A connected HDMI
AV Receiver Sony STR-DH710
PC 1x win7 64 bit, 2x vista 32 bit, 1x winxp sp3
butlerpeter
« Reply #63 on: February 04, 2010, 01:57:02 pm »
This is quite bizarre. The only time I've had scrollbars on the images was with a very early version of Y2M.
I haven't had them appear on any of my images. But, that said, I've not yet trie MarioB's modified skin.
Has anybody got scrollbars appearing that is using a different skin?
Update:-
I've now had a chance to try MarioB's skin and it is something (not sure exactly what at this stage) within the skin that is causing the problem, which explains why I've not seen it before.
Good news is I have modified Y2M to compensate and all seems good.
« Last Edit: February 04, 2010, 02:18:23 pm by butlerpeter » Logged
Shamus
« Reply #64 on: February 04, 2010, 02:23:37 pm »
I get scroll bars with the standard (default) Yamj skin as soon as I reduce either the height or width in yamj to mede8er from 1280 x 720, but not if I leave the settings as 1280 x 720. As I say, with MarioB's skin I need to increase the height to 758 to get rid of the scroll bars. IMO it would be nice to be able to reduce the size settings without the scroll bars appearing, effectively being able to crop slightly to get a better fit on screen.
Cheers
Shamus
Mede8er FW 4.0
Hdd Seagate 1.5 Tb
MarioB
« Reply #65 on: February 04, 2010, 04:16:00 pm »
Guys I'm glad that you like my skin (it's actually Aeon skin with mods)
Shamus, i didn't tried to change font size, and to be honest i don't know exactly which .xls file to modify. You should find somewhere font attributes (font type, size, color ect...) for plot, actors ...
Cheers
butlerpeter
« Reply #66 on: February 04, 2010, 04:19:58 pm »
Font sizes are in the exportdetails_item_popcorn.css file in the HTML folder of the skin.
auren
B8a Tester - X2
« Reply #67 on: February 05, 2010, 03:37:04 am »
@ MarioB
Thanks. Will try that.
Mede8er model: MED500X2
FW: V2.0.0 BETA NOV11
Internal hard disk: Yes
Internal hard disk make/model/size/type: WD500AAJS 500Gb 3.5" SATA
Is your Mede8er networked: No
Type of network: N/A
Display type make and model: Toshiba 40av700e LCD
Audio connection type: HDMI to TV
Omertron
Guest
WWW
« Reply #68 on: February 05, 2010, 01:29:53 pm »
This looks to be a very neat piece of software.
I've been asked a couple of times if YAMJ can produce PNG files for players without HTML capability, so I might point them in this direction Smiley
Let me know if there are any issues and I'll try and help out.
Regards
Omertron (YAMJ Developer)
butlerpeter
« Reply #69 on: February 05, 2010, 01:51:42 pm »
Regards
Thanks Omertron,
if I have any issues I'll be sure to get in touch.
Peter
Administr8or
« Reply #70 on: February 06, 2010, 06:25:39 pm »
Hi All
I have done some modifications to the skin posted by MarioB as per attached sample.
You can download some 1280 x 720 samples here http://www.mede8er.org/artwork/temp/yamj_to_mede8er_examples.rar
Download Skin http://www.mede8er.org/beta/Firmware_Final/yamj_to_mede8er_skin_mariob_modified_lk.rar
This layout also works well on 4:3 aspect ratio TV's
« Last Edit: February 06, 2010, 07:12:22 pm by Mede8er1 » Logged
Des-mond
« Reply #71 on: February 07, 2010, 10:54:32 am »
Mede8er1 & co,  I love the skin  Grin
Good job!
Des-mond
simoncplant
« Reply #72 on: February 07, 2010, 11:19:09 am »
Firstly thanks to all for putting together an awesome solution for the Mede8er :-)
I do have one question though (and I have searched high and low for an answer....) :
Whats the point of the "folder.jpg" ?  It was my anticipation that it was so the move cover could used instead of the naff standard folder icon, to make the whole experience much more graphical, but it doesn't.... so begs the question, whats it for ? :-)
I'm using the modified MarioB's skin and the whole thing looks Fantastic so well done on the about.jpg creation....
Si
MarkMK
« Reply #73 on: February 07, 2010, 08:27:26 pm »
This is all good , nice skin so being as i know a little about YAMJ (i have a eGreat) i might have a look at some other skins
A question i would like to know is this YAMJ is good for when you browse the HDD or network folder but like the eGreat can we not have the mede8er recognise the HTML files so we can open up the entire movie collection this would be a worthy task for someone Smiley .
Mark
Mede8tor MED500X, 1TB Samsung
PlayonHD 500GB WD
eGreat M32B 320GB WD
Hannspree 37" XV-S 720p
« Reply #74 on: February 07, 2010, 08:43:30 pm »
Een voorbeeld voor de Nederlanders hier.
Ik heb hiervoor gebruikt de laatste versie van Mede8er to YAMJ package:
http://www.mede8erforum.com/index.php?topic=1128.msg6666#msg6666
En het template van Mario in dit handige pakketje:
http://www.mede8erforum.com/index.php?topic=1128.msg6918#msg6918
Nederlandse omschrijvingen krijg je automatisch via YAMJ als je deze aanpassing maakt:
http://www.mede8erforum.com/index.php?topic=1128.msg6438#msg6438
Veel plezier ermee.
And for all those others who cannot read Dutch.... I am just explaining over here howto get Dutch descriptions with the nice mede8er YAMJ package. See the added example.
groeten,
« Last Edit: February 07, 2010, 08:49:41 pm by Maasbommel » Logged
Pages: 1 ... 3 4 [5] 6 7 ... 26   Go Up
