Pages: 1 2 3 [4] 5 6 ... 26   Go Down
Author Topic: YAMJ to Mede8er Beta pre-release  (Read 80734 times)
auren
B8a Tester - X2
« Reply #45 on: February 02, 2010, 02:44:52 pm »
In case some of you have older systems like mine, I've experienced that the Y2M program requires that you have Net Framework 3.5.
Mede8er model: MED500X2
FW: V2.0.0 BETA NOV11
Internal hard disk: Yes
Internal hard disk make/model/size/type: WD500AAJS 500Gb 3.5" SATA
Is your Mede8er networked: No
Type of network: N/A
Display type make and model: Toshiba 40av700e LCD
Audio connection type: HDMI to TV
butlerpeter
« Reply #46 on: February 02, 2010, 05:17:14 pm »
Yes it does - sorry should have mentioned that somewhere. Thanks for pointing it out.
Administr8or
« Reply #47 on: February 02, 2010, 07:50:08 pm »
YAMJ to Mede8er BETA 0.6 - 2 Feb 2010
Complete package
http://www.mede8er.org/beta/Firmware_Final/YAMJ_to_Mede8er_pack_Beta0.6_2feb2010.rar
Update only
http://www.mede8er.org/beta/Firmware_Final/YAMJ_To_Mede8er_0.6_BETA_update.rar
Unrar and replace all files in the YAMJ folder and check that your PC has Microsoft .NET Framework 3.5 installed
Updated Manual
http://www.mede8er.org/artwork/temp/User_Instructions_yamj_to_mede8er_2Feb2010.pdf
Change Log 0.6
1. Layout changes
2. Select "single" or "all" file option
2. Changes to resolve win7 64bit issue
3. Fixed issue when last jukebox folder stored could not be found
Peter would really like some feedback so guys pls test this release.
somesatd
« Reply #48 on: February 03, 2010, 02:33:06 am »
One word...  AWESOME!!!
the issue with the black screen with the Mede9er logo has been resolved.  The movies images have been displaying properly.
ButlerPeter, you are DaMan!!!
Please do keep up the good work.  On behalf of the Mede8er community, THANK YOU!
Will continue to test and give more feedback.
« Last Edit: February 03, 2010, 02:42:45 am by somesatd » Logged
Administr8or
« Reply #49 on: February 03, 2010, 05:59:43 am »
Note to Win7 64 BIT users
Pls download MediaInfo_CLI_0.7.27_Windows_x64.zip and replace the files in the "MediaInfo" folder
http://sourceforge.net/projects/mediainfo/files/binary/mediainfo/0.7.27/MediaInfo_CLI_0.7.27_Windows_x64.zip/download
Shamus
« Reply #50 on: February 03, 2010, 08:38:54 am »
I can confirm that the black screen issue has been fixed with win 7 64 bit. My only problem now is the size of the output. Using the standard setting of 1280 x 720 the image is too large for a 4:3 TV so some of the image is lost and changing the aspect ratio in mede8er makes no difference. Changing the size in Yamj to mede8er just crops the final image so again some of it is lost.
Otherwise, great work  Cheesy
Cheers
Shamus
Mede8er FW 4.0
Hdd Seagate 1.5 Tb
Network wired lan Netgear 8 port 10/100 hub
TV Sony Bravia KLV40V550A connected HDMI
AV Receiver Sony STR-DH710
PC 1x win7 64 bit, 2x vista 32 bit, 1x winxp sp3
MarioB
« Reply #51 on: February 03, 2010, 08:51:48 am »
I'm using YAMJtoMede8er and it works perfectly except when I change default skin in YAMJ directory and regenerate moviejukebox folder (I have used different Aeon skin mods). YAMJ2Mede8er shows movie posters (fanart with movie information) properly but the picture is cropped. Then I change output resolution (in YAMJ2Mede8er) to 1280*750, and crop image to 1280*720 with Irfanview. It would be nice if the YAMJ2Mede8er could do that automatically.
butlerpeter
« Reply #52 on: February 03, 2010, 11:40:55 am »
Shamus,
for a 4:3 display you are probably better off having a look for a YAMJ skin that is designed for SD-TV's. I have seen a couple around. The ouput of YAMJ To Mede8er is pretty much controlled by the skin.
MarioB,
As I just said to Shamus the output of Y2M is controlled by the skin, so the fact that images are seemingly being cropped is a bit confusing. Is there any chance you can zip up and make available the skin mods you are using so I can have a look and see what is going on?
MarioB
« Reply #53 on: February 03, 2010, 06:41:03 pm »
Hi ButlerPeter, once again amazing work...
Regarding my problem, I'm using ĈON Movie Wall YAMJ skin
http://www.networkedmediatank.com/showthread.php?tid=25534
with Sabish's Lowlist Mod
http://networkedmediatank.com/showthread.php?tid=25534&pid=326191#pid326191.
The complete skin folder that I use (with my settings) can be downloaded here
http://rapidshare.com/files/345370856/my_default_skin.rar.
You can place my_default_skin in the "C:\YAMJ\skins" folder, rename it  to default (first backup original one Smiley and regenerate your movie jukebox files.
With my Movie database (Jukebox folder and index file), I run YAMJ_To_Mede8er with default settings (Image resolution 1280x720, Quality ~90%) and the result is shown in the attachment. You can see the scroll bars on the bottom and on the right side of the image.
The solution, for now, is to change resolution from 1280x720 to 1280x750 and then crop the image to original 1280x720 pixels (e.g. IrfanView).
butlerpeter
« Reply #54 on: February 03, 2010, 06:56:03 pm »
Ahhh now I understand - not a skin issue at all.
Leave it with me.
Quick question - what is the desktop resolution of the machine you are running Y2M on?
MarioB
« Reply #55 on: February 03, 2010, 07:14:05 pm »
I'm running it on my old laptop with resolution of 1024x768 pixels.
Cheers
butlerpeter
« Reply #56 on: February 03, 2010, 07:34:53 pm »
If yo uhave access to a machine with a resolution higher than 1280x720 could you give Y2M a try on there. I'd be interested to see the result.
auren
B8a Tester - X2
« Reply #57 on: February 04, 2010, 05:19:24 am »
butlerpeter:
Awesome work by the way Cheesy
auren
B8a Tester - X2
« Reply #58 on: February 04, 2010, 05:50:20 am »
Is there a way to process networked files? I have a NAS, the generation of jukebox files worked (index.html, etc) but the conversion from html to jpg didn't work. Error message is:
Saving Image to /192.168.1.....
Error saving image to C:\192.168.1.....
Any ideas? Smiley
auren
B8a Tester - X2
« Reply #59 on: February 04, 2010, 06:31:47 am »
I tried changing the playerrootpath in the moviejukebox.log to //192.168.... and it worked. Smiley Hope there's an easier way though
Pages: 1 2 3 [4] 5 6 ... 26   Go Up
