« Reply #330 on: August 25, 2010, 04:03:46 pm » |
Yes, no problems with YAMJ and YAMJ to Mede8er. It will place about.jpg and folder.jpg in the root movie folder and not in the VIDEO_TS folder.
stijn
Offline
« Reply #331 on: August 25, 2010, 04:40:19 pm » |
whats in fact the difference between yamj to mede8er or tvixie? which one is better? / nicer art?
« Reply #332 on: August 25, 2010, 08:35:43 pm » |
Voor info in Tvixie: http://www.tvixie.com/For info on Yamj: read the Yamj to mede8er topic http://www.mede8erforum.com/index.php/topic,1128.0.html and use the prepared download packages with included manual. Tvixie: easy to use, but more manual to generate the about.jpg files Yamj: fully automated and fast, and more difficult to setup for the first time. But once setup correctly, you don't want anything else....
tachita
Guest
Offline
« Reply #333 on: August 25, 2010, 09:25:46 pm » |
i think stijn ask for :
it will play video dvd with menu from ifo file or it will play first or bigger vob file (no menu structure)?
stijn
Offline
« Reply #334 on: August 26, 2010, 01:35:01 pm » |
tachitaYes, the .xml files are in the jukebox directory. Before using Yamj, I scraped the about.jpg's using TVIXIE but it's an incredible amount of work to scpe and build over 200 about.jpg's with fanart using TVIXIE,..... Using Yamj it scraped 200+ about.jpg's with fanart in 25 minutes, while I was watching TV  See below for the scraped result using the following release of Yamj http://www.mede8er.org/beta/Firmware_Final/yamj-svn-r1416_Y2M_V0.7.1_18Feb2010.rarYamj rules !!! it would be amazing when the mede8er could connect to the jukebox dir on my NAS.....  trying out yamj for the first time, everything works, but i want to change some stuff where do i get the template like the one here at the top of my message? i changed language to dutch, but now more covers arent shown... is there a way to just show the plot in dutch and everything else in english? Written by is also not filled in, or should i put an nfo file with every movie? (a lot of work lol) another question is, once you've run, and new titles are in your library , u have to do everything all over again? or can you just add one title too? thx dutch answer preferred
stijn
Offline
« Reply #335 on: August 26, 2010, 09:03:42 pm » |
i was running yamj, everything ok then i ran yamj to mede8er, everything ok i installed the aon skin, and some mods rerun yamj now i run yamj to mede8er and i get following error
Zie het einde van dit bericht voor meer informatie over het aanroepen van JIT-foutopsporing (Just In Time) in plaats van dit dialoogvenster.
************** Tekst van uitzondering ************** javax.xml.transform.TransformerConfigurationException: Failed to compile stylesheet. 1 error detected.
************** Geladen assembly's ************** mscorlib Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1873 (QFEN-1.050727-1800) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- YAMJ_To_Mede8er Assembly-versie: 0.5.0.0 Win32-versie: 1.0.0.0 CodeBase: file:///C:/YAMJ/YAMJ_To_Mede8er.exe ---------------------------------------- System.Windows.Forms Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Core Assembly-versie: 3.5.0.0 Win32-versie: 3.5.21022.8 built by: RTM CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Xml Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Web Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1879 (QFEN-1.050727-1800) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll ---------------------------------------- mscorlib.resources Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1873 (QFEN-1.050727-1800) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- saxon9he-api Assembly-versie: 9.2.0.3 Win32-versie: 9.2.0.3 CodeBase: file:///C:/YAMJ/saxon9he-api.DLL ---------------------------------------- saxon9he Assembly-versie: 9.2.0.3 Win32-versie: 9.2.0.3 CodeBase: file:///C:/YAMJ/saxon9he.DLL ---------------------------------------- IKVM.OpenJDK.XML.API Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.OpenJDK.XML.API.DLL ---------------------------------------- IKVM.OpenJDK.Core Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.OpenJDK.Core.DLL ---------------------------------------- IKVM.Runtime Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.Runtime.DLL ---------------------------------------- System.Configuration Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- AwesomiumDotNet Assembly-versie: 1.0.8.0 Win32-versie: CodeBase: file:///C:/YAMJ/AwesomiumDotNet.DLL ---------------------------------------- IKVM.OpenJDK.Charsets Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.OpenJDK.Charsets.DLL ---------------------------------------- IKVM.OpenJDK.Util Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.OpenJDK.Util.DLL ---------------------------------------- IKVM.OpenJDK.Text Assembly-versie: 0.40.0.2 Win32-versie: 0.40.0.2 CodeBase: file:///C:/YAMJ/IKVM.OpenJDK.Text.DLL ---------------------------------------- System.Windows.Forms.resources Assembly-versie: 2.0.0.0 Win32-versie: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_nl_b77a5c561934e089/System.Windows.Forms.resources.dll ----------------------------------------
************** JIT-foutopsporing ************** Als u JIT-foutopsporing wilt inschakelen, moet in het configuratiebestand voor deze toepassing of computer (machine.config) de waarde jitDebugging in het gedeelte system.windows.forms zijn ingesteld. De toepassing moet ook zijn gecompileerd terwijl foutopsporing was ingeschakeld.
Bijvoorbeeld:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
Wanneer JIT-foutopsporing is ingeschakeld, worden onverwerkte uitzonderingen naar het JIT-foutopsporingsprogramma gestuurd dat op de computer is geregistreerd en worden niet door dit dialoogvenster verwerkt.
« Reply #336 on: August 26, 2010, 09:14:58 pm » |
reason is on top: Failed to compile stylesheet. 1 error detected
You made some errors in your customized sheets.
stijn
Offline
« Reply #338 on: August 26, 2010, 09:30:06 pm » |
anyway before adjusting that again im using the standard thing. i ran a test again , and again ,like with tvixie; it doesnt do what it should do with video_ts structures i get rare things one time, he show me the correct movie with another movie, he just picks a random other movie to play and with a third, he doenst play anything at all but flips back to d:\movies folder rare thing, i think its a bug inside mede8er?
stijn
Offline
« Reply #339 on: August 26, 2010, 09:32:11 pm » |
i already downloaded that package, it has only 5 skins (2 HDskins) but not the aon skin... like the one above showing "shooter"
Jark
Offline
« Reply #340 on: August 27, 2010, 09:16:53 am » |
Maasbommel, Could you please tell me how to change exactly the setting for Dutch language (moviemeter api)? I tried It like you mentioned in this topic before, see also my post from a few days ago. For some reason I still got English please help ;-) Thanks in advance. Jark
« Reply #341 on: August 27, 2010, 12:18:08 pm » |
Hi Jark,
In the moviejukebox.properties that is in the YAMJ folder, add the following:
mjb.internet.plugin=com.moviejukebox.plugin.MovieMeterPlugin thetvdb.language=nl
regards, Maasbommel
Jark
Offline
« Reply #342 on: August 27, 2010, 12:57:55 pm » |
Hi Jark,
regards, Maasbommel
Thanks. In the YAMJ folder there's no moviejukebox.properties file. There is one in the Properties folder. In the folder there's also a moviejukebox-default.properties file... I added it to the moviejukebox.proprties file, so it looks like this: ############################################################################################################ ## Movie Jukebox properties ## ## This provided as an example moviejukebox.properties file. ## ## You *MUST* copy or move this file to the root folder of your installation (1 folder up) for it to work ## You can then add the properties you want to change from the moviejukebox-defailt.properties file ## ############################################################################################################
# This is the skin property, you will need to change this if you want to change the look of YAMJ mjb.skin.dir=./skins/default
# Add other properties here mjb.internet.plugin=com.moviejukebox.plugin.MovieMeterPlugin thetvdb.language=nl I also copied it to "the root folder of your installation (1 folder up)", but still no Dutch language.......
« Last Edit: August 27, 2010, 01:06:36 pm by Jark »
« Reply #343 on: August 27, 2010, 01:10:47 pm » |
That is probably because your moviejukebox folder already contains things in english and generated things are not overwritten by default by Yamj.
Just empty your jukebox folder and regenerate it by running the My_YAMJ.cmd file
zifnabbe
Offline
« Reply #344 on: August 28, 2010, 03:25:24 am » |
nice to know ie. concerning the properties file. Is this somewhere document? (are there more properties)
Is there a way to use the eg moviemeter thumbnails as well?
