Author Topic: problem streaming mede8r 1000 - Samsung UE37D6510  (Read 3304 times)
Offline shex
« on: April 08, 2013, 09:09:01 PM »
Hi everyone,
I have a problem streaming files from  Mede8er MED1000X2D f/w v1.0.5 to Samsung UE37D6510, files on mede8r are visible on TV (both internal HDD and USB), but when I try to play ANY TYPE of file is says "file format not supported". I have two more PCs and i have no problem watching any files in my shared folders on mede8r 1000 via network. I have tried some combination DLNA and samba on mede8r but with no sucess. TV and mede8r are with static IP. I use d-link switch (TV and mede8r are connected to this switch) and Thomson 780 router.
I tried to find some useful info in this forum and Internet but nothing helped. In short I can't use mede8r 1000 as NAS with Samsung smart TV, hopefully not for long.
I would appreciate some help... thanks
« Last Edit: April 09, 2013, 06:35:03 AM by shex »
Re: problem streaming mede8r 1000 - Samsung UE37D6510
« Reply #1 on: April 09, 2013, 08:27:06 AM »
You  are using upnp and that requires devices to share information  about what can or cannot be played.  The Med's server strictly adheres to  that  transfer, many other servers on PC's etc allow you  to ignore it..and see if it plays or not.  The enginneers would have to look at if the SDK has any users options but I can't say if they will  or not.
Offline shex
« Reply #2 on: April 09, 2013, 11:05:30 AM »
So there is no way of changing any settings in addition to make it work?
« Reply #3 on: April 09, 2013, 11:38:52 AM »
Currently the upnp server/DMS only has on/off control, and no fine tuning.
Offline lbondon
« Reply #4 on: November 05, 2014, 08:53:17 PM »
I have exactely the same problem I think. Did you find out how to solve it ?
http://www.mede8erforum.com/index.php/topic,15318.0.html
I have the feeling that there is a pb with "streaming to samsung TV"...
if you have news, I'm happy to hear from you
Laurent
