Author Topic: V2.1.1 - 3April for ME500X2, MED450X2, MED400X2, MED400X2S - 0PEN BETA -  (Read 30633 times)
Hi all Mede8er X2 owners
Thanks to the ongoing development on the X3D Series we are now able to port some of our enhancements across to the X2 Series.
NOTE: All Hard drives must have a unique name for correct functionality with V2.1.1 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc
Install V2.1.1_April03_2013_BETA
Install using the Emergency Procedure
http://www.mede8er.org/beta//Firmwares_Beta/MED500X2_BETA/V2.1.1_April03_2013_BETA.zip
Changelog  V2.1.1 - April03 2013
1. Fixed - crashing when selection 'Sort by Latest' in Movie JukeBox
Changelog  V2.1.1 - 29March 2013
1. New Functionality Mede8er JukeBox Plus
JukeBox Plus is new functionality within the X2 Firmware that will allow you to Aggregate your Movie JukeBoxes across different sources such as internal Hard Drive, USB Drives and Network shares both Samba and NFS. There is no limitation to the amount of Movie JukeBox's that can be added to JukeBox Plus and just remember that the source shares must have the required Mede8er folder structure with the correct images and xml files. JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files.
2. Added - Compound Filtering in Movie JukeBox
3. Added - 3 Row Movie JukeBox - Select 'Hide Movie Info' in Movie JukeBox to enable 3 Row View
4. Added - Watched/Unwatched filter for Movie JukeBox searching
5. Added - Watched Indicator icon on Thumbnail.
6. Updated DLNA DMS / DLNS DMR
7. Updated images for DLNA music playback to match the rest of the GUI.
Online Guide - http://www.mede8er.com/mede8er_JukeBox_Plus_user_guide_V0.html
JukeBox Plus Instructions
Emergency Procedure
Known Bugs - Sort search by latest in movie jukebox cause X2 to crash
« Last Edit: May 23, 2013, 09:32:26 am by Mede8er1 »
Possible Bug as found on X3d :-
1) If you  create a Jukebox+ on a NAS and then remove the Jukebox+ Favourite, the option to  set the Aggregate Jukebox+ doesn't return to  the Menu.  The only solution  found is to  re-install the firmware.
Hosting Jukebox+ on attached storage  is working as expected. We would advise those using a NAS should host Jukebox+ on a local SD card anyway..as the GUI is much  faster that way.  Those using a Nas won't appreciate that  as your standard  jukeboxes have always been on the NAS so  far.
