Author Topic: V2.1.1 - 29March for ME500X2, MED450X2, MED400X2, MED400X2S - 0PEN BETA -  (Read 10383 times)
Hi all Mede8er X2 owners
Thanks to the ongoing development on the X3D Series we are now able to port some of our enhancements across to the X2 Series.
Install V2.1.1_March29_2013_BETA
Install using the Emergency Procedure
http://www.mede8er.org/beta//Firmwares_Beta/MED500X2_BETA/V2.1.1_March29_2013_BETA.zip
Changelog  V2.1.1 - 29March 2013
1. New Functionality Mede8er JukeBox Plus
JukeBox Plus is new functionality within the X2 Firmware that will allow you to Aggregate your Movie JukeBoxes across different sources such as internal Hard Drive, USB Drives and Network shares both Samba and NFS. There is no limitation to the amount of Movie JukeBox's that can be added to JukeBox Plus and just remember that the source shares must have the required Mede8er folder structure with the correct images and xml files. JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files.
2. Added - Compound Filtering in Movie JukeBox
3. Added - 3 Row Movie JukeBox - Select 'Hide Movie Info' in Movie JukeBox to enable 3 Row View
4. Added - Watched/Unwatched filter for Movie JukeBox searching
5. Added - Watched Indicator icon on Thumbnail.
6. Updated DLNA DMS / DLNS DMR
7. Updated images for DLNA music playback to match the rest of the GUI.
JukeBox Plus Instructions
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
Known Bugs - Sort search by latest in movie jukebox cause X2 to crash
« Last Edit: March 29, 2013, 10:07:03 pm by Mede8er1 »
Please note.
The X2 has the "latest"  Jukebox+ code.  If you read Couto's excellent guide for Jukebox+ on the x3d you will not find item 8 ) above.   This simpler way of adding direct from Favourites hasn't yet made it to  the X3D!
