I presume you have tried slave mode? Disconnected the x3d from the TV etc, moved it to a PC and connected using the blue lead to a USB port on the PC? When you do that the internal drive should appear as one of the drives in Windows Explorer. Right click on the drive, select Properties, and therw should be a blank Volume Name on the General Tab. Give the drive a meaningful name.
