Author Topic: AGGREGATE JUKEBOX in with Firmware 15 MARCH V2.0.0  (Read 29647 times)
Offline couto
« on: March 15, 2013, 09:05:12 PM »
hi made a simple tutorial to serve has guide, how to use the aggregate jukebox in new firmware 15 march v2.0.0
FIRST.....SCRAPPE all your library in different localizations with different Mede8er community tools  available on this topic
http://www.mede8erforum.com/index.php/board,103.0.html
i use yadis + yadis2mede8er (windows) and duneX + duneX2mede8er  (mac ) theres also other good scrappers  avaiable.
secondly after your jukebox are working in X3D ,  you can start the aggregation process, by installing the latest firmware of 15 march 2013 and follow the instrucution bellow .
« Last Edit: March 16, 2013, 01:10:19 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline couto
Re: AGGREGATE JUKEBOX in with Firmware 15 MARCH V2.0.0
« Reply #1 on: March 15, 2013, 09:06:54 PM »
« Last Edit: March 15, 2013, 09:12:44 PM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
« Reply #2 on: March 15, 2013, 09:09:36 PM »
« Last Edit: March 16, 2013, 01:09:18 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Re: Re: AGGREGATE JUKEBOX in with Firmware 15 MARCH V2.0.0
« Reply #3 on: March 15, 2013, 09:24:35 PM »
Like! We need that button here!
Offline feadin
« Reply #4 on: March 15, 2013, 10:35:33 PM »
+1, couto, you are the man!
Offline Zakkie
« Reply #5 on: March 16, 2013, 07:49:36 AM »
Nice Tut!
Well done....and thank you.
Offline Mahoni42
« Reply #6 on: March 16, 2013, 09:00:37 AM »
Great, thank you  ;D
MED600X3D
Wired Network
Router: FritzBox 7270
TV TH-42PV60E 42" Plasma
Projektor SONY VPL-HW50ES
2,8m Tension Screen
Yamaha RX-V767 AV Receiver HDMI 1.4, all via HDMI
USB Hub with three HDDs, USB Dongel Logitech K400
Media Files: DVD ISO, BD ISO, 3D ISO
Media Source: Western Digital, Fantec
Video setting: 24Hz On, auto frame on
Offline gabrielydante
« Reply #7 on: March 17, 2013, 01:07:30 PM »
Thanks Couto, i have one question. I have around10 hard drives (external drives) if i connect in example  2 hdd to medder and built the agregate jukebox,  then i unplug one hdd and connect another one, what happen with the files on the unpluggeg hdd?
And in several hdd i have separate the 3d movies in a subfolder that haven ’t the possibility for filter on the xml search, in your opinion which is the best option for filter the 3d movies in the jukebox?
« Last Edit: March 17, 2013, 04:27:29 PM by gabrielydante »
« Reply #8 on: March 17, 2013, 01:28:54 PM »
Every drive must have a unique Volume Name. So you will  be told movies on the removed drive are not available when you chose one.
Offline Reefius
« Reply #9 on: March 18, 2013, 04:17:56 PM »
Is it possible to create more than one aggregated jukebox? For example one for movies and one for tv shows.
« Reply #10 on: March 18, 2013, 04:21:34 PM »
Only if you use Jukebox for TV shows. Most people end up using the TV wall for TV, which  can't be jukeboxed.
Offline SOCWRKR
« Reply #11 on: March 19, 2013, 03:28:56 AM »
Hi, all of the steps listed above worked just fine until when I tried to add my files to the aggregate jukebox.  When I do this it keeps saying "0 movies added".  It's doing this for all of my folders.  Any ideas guys? thanks so much for any help!
mede8er 1000x3 v1.3 Sept. 29. HDMI 1.4
Onkyo NR3008
Audio setting passthrough
Samsung 63C8000
Media Source: Internal 2TB Seagate
Media Source: External WD My Book 3TB
Media Source: Seagate external 1TB
« Reply #12 on: March 19, 2013, 09:04:26 AM »
The internal aggregator is not an internal scraper. You have to add the host folder for an existing conventional  jukebox which  was created by external scraping.
Offline SOCWRKR
« Reply #13 on: March 19, 2013, 09:21:05 PM »
Ok, so i am using yamj on my computer to get the artwork and everything.  I'm a bit lost on this i guess.  Do i need to put something like yamj on one of the hdd i use for the movies? If there is directions on how to do this, you could just point me in that direction and i'll try to figure it out.  Thanks again.
Onkyo NR3008
Samsung 63C8000
« Reply #14 on: March 19, 2013, 09:46:25 PM »
Are you already running ordinary jukeboxes?   If you are you should have multiple jukebox favourite links.  It's the folders those point to that  you add to  the Jukebox+.
