Author Topic: TVRename - Tv Wall application  (Read 401229 times)
Offline Zakkie
  • Moder8or
Re: TVRename - Tv Wall application
« Reply #495 on: May 04, 2015, 12:32:50 PM »
I have problems with the Tool. First time i get very often a crash and on next start i musst select a backup. Second one whene i file have this name tvs-bloodline-dd51-dl-18p-nfhd-x264-111 its not renamed. I use Windows 8.1 with all Updates. Is there a alternative Tool which is more stable?
Hi Scoty,
tvs-bloodline-dd51-dl-18p-nfhd-x264-111 < I assume this is S01 E11?
If so rename it so the program can compute the naming convention: > Bloodline S01E11 (or what ever it should be)
Crashes: program is very stable (even under windows 10)
Bad memory or HD errors can cause major issues as well.
Regards
Z
Offline Scoty
Re:
« Reply #496 on: May 04, 2015, 03:11:09 PM »
My Memory and Hdd are OK.
Offline riaanstrydomza
« Reply #497 on: October 28, 2015, 06:38:48 PM »
Zakkie,
Any ideas why a series that is in double digit, ie s10/11/12/13 will not be picked up if files are named series.1203.x264 (is s12 e03)
Offline Tarl
« Reply #498 on: May 21, 2016, 01:04:40 PM »
At random the "+" mark disappears in "my shows" and I can't sea any episode information. I have tried the "Tools > Force Refresh All" option, but all "+" marks and informations have disappeared.
Update:
No errors found in TVRename
Also checked with Steve (TVRename author):
"I haven't noticed any issues with the shows I'm watching.
Sometimes it can get out of sync with thetvdb.  Try the "Tools > Force Refresh All" option.  That will make it re-download everything, which might fix it.
Or, if it just one or two shows, you can right-click on them in My Shows, and choose "Force Refresh".
From Steve -
I had a few issues similar to the others in this forum and Force Refresh worked for me.
Regards
Zakkie
Offline jose111
« Reply #499 on: July 21, 2016, 09:11:28 AM »
You can force refresh only the show without the mark+, and after that, you can do the full scan to download the information and images.
Note: now you have to run a full scan to download all information and images again.
From my Bacon Machine powered by Darkobas
« Reply #500 on: October 13, 2016, 12:14:22 PM »
Zakkie,
Is there anyway TVRename could write the index file for root TV folder so it becomes searchable in Mede8er?
Offline Thebudac
« Reply #501 on: December 13, 2016, 03:25:19 PM »
Hi, any one else experienced the problem where the preferences no longer has the Media Centre tab?
Offline juleloup
« Reply #502 on: December 31, 2016, 03:51:14 PM »
Hi all,
I'm unable to setup the MediaCenter tab, it's greyed out.
Does anybody know how to fix this?
I'm running Windows 10 Pro, maybe that's why?
Thanks in advance,
Juno
Offline juleloup
« Reply #503 on: January 02, 2017, 11:06:26 AM »
Never mind, I've solved the issue.
Here is my solution:
If you are still unable to setup the Media Center tab, uninstall TV Rename, but also remove the following folder.
C:\Users\%Username%\AppData\Roaming\TVRename
Then re-install the TV Rename 2.2.4 which you've downloaded from this forum/Mede8er site.
After installation, you should be able to setup the Media Center tab, at least I did! :-D
Happy TV Rename using and a happy new year to you all.
Siull
  • Guest
« Reply #504 on: September 23, 2017, 10:31:46 AM »
I know that this is an old threath, but the mede8er internal TV series scraper stoped work last month, (api problems  and no more firmware updates).
It is a really good job, but the language option does not work. The only language I get is english. That is enough for the most of you, but I'd like to get the episodes and sinopsis also in spanish. Is this possible?
Thank you in advance.
P.D.: Sorry for  my english.
Offline LarryM8
« Reply #505 on: September 25, 2017, 05:30:06 PM »
They are just working on the language feature. Just wait until they are finished.
Offline xlr8r
« Reply #506 on: October 12, 2017, 11:25:55 AM »
can someone advise me how to get the tv series , folder.jpg and fanart.jpg to be added to the folder.
at present, im just getting the xml files but no jpg's ? The season folder appear to be populating ok with jpgs' ?
Tv Series folders after scanning, looks like this; (missing folder.jpg and fanart.jpg)
Tv Series, Season folders after scanning are ok, ie like this
here are my settings;
thanks in advance
Offline LarryM8
« Reply #507 on: October 15, 2017, 10:50:30 AM »
The version 2.3b1 is a beta version and has some bugs.
Meanwhile they fixed a lot of bugs, but there is no release yet.
The current version on github is working very well, so i think it will not be very long until a new version is released.
Offline dxer
« Reply #508 on: October 15, 2017, 05:41:14 PM »
Maybe stupid question but...is there any manual for using this tool for scraping tv series.
I tried something but it is not clear to me how to scrape and where ti find files produced from scraping
Offline LarryM8
« Reply #509 on: October 16, 2017, 03:48:07 PM »
Yes,
it is included in the application.
Have a look at the "Help" menu.
