Author Topic: Automatic FourCC Changer  (Read 108224 times)
Offline KlDieter
Re: Automatic FourCC Changer
« Reply #30 on: November 26, 2013, 06:56:01 PM »
Danke, jetzt kann ich alles wieder sehen.
Offline Tistitoo
« Reply #31 on: December 30, 2013, 11:57:40 AM »
Great thanks for your job (it's work very fine)! Application indispensable pour ma collection d'AVI (ressuscité!) Merci!
Offline vfundz
« Reply #32 on: February 10, 2014, 01:50:18 PM »
Thanks for this great tool. Any solutions for DIV3 files yet besides reencoding?
Offline Lupissimo
« Reply #33 on: February 10, 2014, 03:04:08 PM »
I am afraid not.
Offline meddyb
« Reply #34 on: March 23, 2014, 12:52:21 PM »
Please can so tells me ghow to scan a networked hdd please ?
Offline Lupissimo
« Reply #35 on: March 23, 2014, 01:08:16 PM »
If you have a Windows Network, you can attach the networkdrive within windows and then use the Drive Letter: eg: D:\ or E:\ etc.
Offline Dabber01
« Reply #36 on: June 26, 2014, 08:27:06 AM »
Hello All
First of all I must start by saying I am not a "Techie" therefore hope you will bare with me ....
I need to change the codec on the vast majority of my media files to XVID and have kindly been sent the link to the FourCC program however unfortunately I am struggling to understand how to use it ...(see above). Is there anybody out there who would be kind enough to provide an idiot  guide for me? I have my media stored on an external 3tb drive and would say that about 85% of it has been converted to AVI DIVX ...... it's a big problem
Hope somebody can help and thanks for reading
Offline Lupissimo
« Reply #37 on: June 26, 2014, 03:49:44 PM »
When you connect your external drive to your Windows PC there will be a drive letter assigned to it: e.g.: D:\ or E:\
This is the "Start Pfad" in the window which you open by starting the Lupos_FourCC.exe.
The Lupos_FourCC.ini for just scanning your files and indicating in the listing of Lupos_FourCC.txt which files are using what Four_CC, should look like this:
StartDir = E:\
Endungen = AVI, MKV
suchen   = DIVX, DX50
ersetzen = ; XVID  ; kein Ersetzen = nur Liste  << ; befor XVID
Protokoll überschreiben = FALSE
To replace the Four_CC it should be:
StartDir = E:\
Endungen = AVI, MKV
suchen   = DIVX, DX50
ersetzen = XVID
You terminate the program by using [ESC] and [Enter]
Offline Dabber01
« Reply #38 on: June 26, 2014, 07:57:12 PM »
Many thanks , I'll give it a go now
Offline Dabber01
« Reply #39 on: June 26, 2014, 11:08:19 PM »
Hi
I gave this a go and unfortunately still no joy. I think I am doing something which is very basic wrong. This is what I did:
1) opened .ini file and changed the location to E:\media (my external drive and file location)
2) ran the main program
3) entered E:\media\films (folder to be scanned)
4) entered to run the scan
5) escaped then enter to end the program
Tried the external drive again tonight on the media player and the files that were divx still are saying are unsupported format. I think it's me being stupid but what am I doing wrong?
Offline Lupissimo
« Reply #40 on: June 27, 2014, 04:24:54 AM »
Whether anything was changed you can see in the Lupos_FourCC.txt protocol. I assume you used the ini with "ersetzen = XVID" and not with "ersetzen = ; XVID"  which only gives a list of potential files to be changed.
Can you check, whether those files are DIV3 , which is NOT divx and not compatible with the xvid codec. There is no solution for those files other than reencoding the movies.
Offline Dabber01
« Reply #41 on: June 27, 2014, 08:06:39 AM »
Hi Lupissimo
Thanks for your assistance you're very kind
The codec is definateley DIVX as I have checked the software used to transfer from DVD. Everything else you asked me to check is also fine however I can't find the information on whether the files have been altered ...... the list I can see has the test default listing (G:\movies etc) not any of my files. Does this suggest my files have been converted or that like an idiot I'm looking in the wrong place?
Chris (Dabber01)
Offline Dabber01
« Reply #42 on: June 27, 2014, 08:33:48 AM »
Hi Lupissimo
Can you confirm that the Lupos_FourCC.txt protocol is the 7th folder down. If so this is not showing any of my changes once i've ran the scan
Dabber01
Offline Lupissimo
« Reply #43 on: June 27, 2014, 11:11:52 AM »
Just to be sure the program finds anything do the following : Rename the 2 files "Lupos_FourCC.txt" and "Lupos_FourCC_ini_und_Protokoll.txt" so that new ones are created. Then you should run the program with "ersetzen = ; XVID" in the ini file. That way the program just lists your files without changing anything. Then just post a couple of lines of the Lupos_FourCC.txt files, so we can see whether any files were found at all.
By the way: To start the program after you have opened the command window by double clicking on the .exe file, you have to hit [Enter].
« Last Edit: June 27, 2014, 11:25:26 AM by Lupissimo »
Offline Dabber01
« Reply #44 on: June 27, 2014, 03:48:36 PM »
Hi Lupissimo
Here is a copy of the Lupos_FourCC.INI screenshot
 StartDir = F:\
Endungen = AVI
suchen   = DIVX,DX50
ersetzen = XVID  ; kein Ersetzen = nur Liste
F:\   is my drive address
Here is a copy of a couple of lines of the Lupos_FourCC.TXT after the scan of the F:\ has been scanned
XVID/XVID ->    dto.      G:\MOVIES\MOVIES OVERIGE TEST\17 Again (2009)\nedivx-17again.avi
XVID/XVID ->    dto.      G:\MOVIES\MOVIES OVERIGE TEST\4 Music videos\Pink Floyd - Pulse (1994)\Pink Floyd - Pulse 1994.Concierto.avi
XVID/XVID ->    dto.      G:\MOVIES\MOVIES OVERIGE TEST\40 Days & 40 Nights\40 Days & 40 Nights.avi
H264/H264 ->    dto.      G:\MOVIES\MOVIES OVERIGE TEST\5 Series\Chicago Fire\Season 1\Chicago Fire S01E01.avi
As you can see it hasn't listed any of my files but retained the test listing .....
