Author Topic: [TIP] Copying files using the Mede8er  (Read 2839 times)
Offline Insomniac
  • Moder8or
  • B8a Tester
« on: October 09, 2009, 11:56:47 am »
Should you be experiencing any difficulty transferring files using the Mede8er GUI, please use this guide:
    1. Go into the File Manager feature
    2. In the 'Source' window on the left, navigate to the source folder
    3. Use the 'SELECT' button on the remote (bottom left) to select one or multiple files/folders
        (Selected files & folders will be marked with a green tick)
    4. Press the 'RIGHT' arrow to jump to the 'Destination' window on the right
    5. Navigate into the destination folder
    6. Press the 'RIGHT' arrow again to perform the move.
« Last Edit: October 16, 2009, 07:39:15 am by Insomniac »
