Author Topic: NEWBIES TUTORIAL YADIS + YADIS TO MEDE8ER  (Read 107004 times)
Offline couto
« on: February 16, 2013, 11:16:18 pm »
Tutorial YADIS TO MEDE8ER
This is a simple guide step-by-step to make a jukebox the easy way.
While the developer of YADIS doenst launch a final version to mede8er player profile, it will be necessary to use 2 simple programs to built the jukebox
1-  donwload yadis 2.2 http://yadis.whisperingvault.net/projects/yadis
new yadis 2.3 with updated TMDB API is here : http://www.mediafire.com/download/8f0ybl14ckub6po/yaDIS_2.3.exe
2- download yadis2mede8er http://www.mede8erforum.com/index.php/topic,10081.0.html
FILES
Having the correct names in file and the same in movie, is a great step forward for the program make the correct scrapping/jukebox.
Its essencial that any hard drive, in any network or external/internal disk, having a sub-folder, its essencial to add to favorites in later step.
i recommed that follow this sub- folders settings in all hard drives, it will also be important in jukebox aggreagation in future versions.
A- shared file
B- file that will be add to favorites (sub-folder)
C- file with movie name.
D- movie name.ISO or .mkv etc
ps: forget the usual reaname using year  ex:  avatar (2009) because the .xml file has the option to choose movie by year, type etc.
« Last Edit: September 23, 2013, 09:10:36 am by Maasbommel »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline couto
Re: NEWBIES TUTORIAL YADIS + YADIS TO MEDE8ER
« Reply #1 on: February 16, 2013, 11:17:08 pm »
YADIS 2.2
Download and install YADIS 2.2 in pc windows
1- go to setup
1-choose language of preference
2-choose dune perfil
3- choose basic mode
4- choose folders
5- choose add (this is where we tell yadis where are our movies )
6-choose yellow icone to choose the file localization to make the scrapping
7- go through your files in pc until finding the hard drive that has the file to scrappe (in this case i choose computer)
8- in this example the hard drive is called "NO NAME" (P : )
9- OK
10-  Has you can see i choose the drive (P : ), if i had sub-folder it would have  (P: )\\VIDEO
11- ok
12- Has you can see i choose the drive (P : ), if i had sub-folder it would have  (P: )\\VIDEO
13- ok
PS: see the other examples where i access by network to my NAS synology or the external drive attached to X3D, you can scan the movies by any network.
« Last Edit: September 02, 2013, 02:17:36 pm by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
« Reply #2 on: February 16, 2013, 11:17:54 pm »
after cliking  ok
14- in red are the movies that needs to scrappe
15- in blue are the movies already scanned by yadis
16- to auto scan choose process
ps: you can choose all movies at once to make full scrapping
pps : you can process one movie individually, or when yadis choose the wrong movie scrapper, you just do right click on top of that movie to make manual search of the scrapper.
17-  Yadis doesnt scan the type of audio or subtitles in ISO files (you need to put manually ) but all the other files the scrapping is complete.
you also can choose the type of cover or fanart according to your preferences.
AT THIS POINT YOUR MOVIE  SCRAPPING IS COMPLETE, ITS ONLY REQUIRED ONE MORE STEP WITH THE OTHER PROGRAM THE YADIS2MEDE8ER.
« Last Edit: September 02, 2013, 02:21:23 pm by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
« Reply #3 on: February 16, 2013, 11:18:33 pm »
YADIS2MEDE8ER
Do the download of yadis2mede8er link  first post and open yadis2mede8er versao 1.0 beta 17
18 - send all-  it scans the entire yadis workspace (where your movie cache scrapping is  ) leave un-tick if you only want to scan last movies added.
19 - its the localization where the files are to scan, if you see picture 2 from post #2 its the same localization.
c : program file (x86)\yaDIS\workspace (this was the place where YADIS was installed in my pc, in your can be different)
20- save settings
21- click mede8rize
22- the yadis2mede8er will scan and create a .xml file to everymovie or just the update if theres any changes made.
23- example of the file
24- exemple  of what has being made/created with both programs
« Last Edit: September 02, 2013, 02:22:46 pm by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline couto
« Reply #4 on: February 16, 2013, 11:19:16 pm »
JUKEBOX IN  X3D
After having scaned all the hard drives and doing the scrapper with YADIS and  Yadis2mede8er plug it in usb port (if is the case).
A- go setup
B- Put Jukebox view ON
C- Go to media library
D- go to the SUB- FOLDER ( hard drive or NFS or SAMBA ) that we scan before in my case was  (p: ) push the menu button and the in right side choose ADD TO FAVORITES
E- go back and go to FAVORITES, go to the file you just add and push menu button to SCAN FOLDER
F- browse in that same file and you will have a 2 row jukebox, press menu button HIDE MOVIE INFO
The final result is something like this
very easy..enjoy
« Last Edit: September 02, 2013, 02:31:11 pm by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Protocol : UDP 32K
Offline NoZEM
« Reply #5 on: February 17, 2013, 02:52:46 pm »
Well done couto!
This tutorial must be sufficient for most people.
You must have plenty of spare time. You are active on lots of other fora  ;D
MED600X3D -> HDMI -> Marantz NR1603
Streaming from Synology 212+ NAS -> NFS
Philips 40PFL9705
___________________________________
Bedroom: MED600X3D -> HDMI -> Philips 32PFL9604
Offline Whooper
« Reply #6 on: February 18, 2013, 03:09:29 pm »
What to do when the film is not correctly identified?
In the anime film "Brave" the Yadis identifies it as another movie.
I tried to put a NFO file with the URL corresponding to the IMDB movie I want, and also not given.
What to do?
Sorry my English is not the best, I'm using the Google translator.
Offline funkycochise
« Reply #7 on: February 18, 2013, 03:32:25 pm »
What to do?
select "change Name" in the contextual menu in Yadis
Offline Mr Eric
« Reply #8 on: February 18, 2013, 03:57:54 pm »
What to do?
yadis is much easier to use than yamj...  ;D
just right click the title and "change title" and use the search field to find the correct movie in tmdb.  ;)
Yadis beta team member
Offline est1980
« Reply #9 on: February 25, 2013, 02:39:51 pm »
i am really new to all this so you will have to forgive me, ive been having propblems with new films ive added showing up, i thought id sussed it after following your tut step by step
but same result, any new movie i add just doesnt show up on my movie wall, all info etc has been scraped and all the movie art is in there folders
any idea what im doing wrong?
« Reply #10 on: February 25, 2013, 02:50:06 pm »
That may not be a yadis issue.  Some users are getting the NTFS journal locked due to  file issues, and an older journal is used instead which  dosn;t contain the new movies.
Offline est1980
« Reply #11 on: February 25, 2013, 07:26:23 pm »
anything i can do?
Offline cmak
« Reply #12 on: March 15, 2013, 11:28:23 am »
What about if you having Mac and not windows?.
« Reply #13 on: March 15, 2013, 11:33:03 am »
Then  you have to use Dunex...not Yadis.
http://www.mede8erforum.com/index.php/board,105.0.html
« Last Edit: March 15, 2013, 11:39:23 am by jer1956 »
« Reply #14 on: March 15, 2013, 12:20:39 pm »
I'm working on iMac, and I use a virtual Machine for Yadis.
I find the picture generated in Yadis fits more my tastes.
