Author Topic: Template for Yadis  (Read 51783 times)
Offline dobermanUK
Re: Template for Yadis
« Reply #45 on: May 31, 2015, 03:29:18 AM »
I am getting this weird overlapping effect with the text and can't figure out why!
Offline dobermanUK
« Reply #46 on: May 31, 2015, 12:05:35 PM »
It seems I have to alter the template.xml file till things look right?
Any idea why I am getting this?
Thanks in advance
Update: I tried a 32 bit machine and it creates the templates perfectly!
              It seems that the 64 bit version of Windows is causing the issue. If there is anything I could do in order to make the 64 behave properly, please let me know!
« Last Edit: May 31, 2015, 03:14:09 PM by dobermanUK »
Offline Mr Eric
« Reply #47 on: June 02, 2015, 08:38:49 AM »
it's not the template. You are certainly using large fonts in windows (>100%). just set your fonts back to 100% in windows and reprocess your movies, everything should go back to normal.
Yadis beta team member
Offline dobermanUK
« Reply #48 on: June 03, 2015, 08:19:41 AM »
Thanks, it worked!
Fonts were changed to 125%; putting them back to default did the trick...
Offline pallec
    • Guitarfix
« Reply #49 on: September 26, 2015, 11:27:22 AM »
I have problems with all letters being CAPITAL after upgrade to Windows 10  :(
Connected to:
Netgear C6250 router
Synology DS214+ NAS (NFS)
Samsung UE65F8000 TV
Panasonic PT-AE2000 Projector
SONY STR-DN1040 AV Receiver
www.guitarfix.dk
