Author Topic: Template for Yadis  (Read 44137 times)
Offline rafal180
Template for Yadis
« on: February 11, 2013, 02:35:03 am »
Hi  :)
I made a Yadis template which is combination of standard "Glass Revisited" and "Tribute Full" from mpcclube.  I wanted to made larger fonts that can be readable from a distance, but also a lot of space for fanart image and plot while maintaining all important data. Localized in 18 languages.
Download link: http://www.embedupload.com/?d=52BQKADUIY
UPDATE 11.01.2014
New version (2.0) of the template remix based on standard "Glass Revisited" and "Tribute Full" from mpcclube  :)
Changelog:
- Change name of the template to Tribute Glass Mix and add preview image
- Larger font size for cast and directors
- Larger poster size
- Larger size of icons fot subtitles and audio
- Fix transparency and color layout
- More space for fanart
- Change the position of each icon and font
- Many other minor changes in layout (colors, fonts size etc...)
Link for Full size image preview:
Image 1
Image 2
Download link: http://www.multiupload.nl/SIRMYZOS4H
UPDATE 14.01.2014
New version (2.1)
Changelog:
- change the position of country flags witch forcing change the position of other elements (audio, subs, runtime, duration)
Image 1
Download link:
Mirror 1 (turbobit) Tribute Glass Mix.rar
Mirror 2 (bitshare) Tribute Glass Mix.rar
Mirror 3 (4shared) Tribute Glass Mix.rar
Mirror 4 (1filesharing) Tribute Glass Mix.rar
Mirror 5 (digzip) Tribute Glass Mix.rar
Mirror 6 (embedupload) Tribute Glass Mix.rar
Mirror 7 (directmirror) Tribute Glass Mix.rar
Mirror 8 (megafileupload) Tribute Glass Mix.rar
Mirror 9 (speedyshare) Tribute Glass Mix.rar
Mirror 10 (mediafire) Tribute Glass Mix.rar
Mirror 11 (sendspace) Tribute Glass Mix.rar
Enjoy  ;)
« Last Edit: July 02, 2014, 12:34:46 am by rafal180 »
Offline Mr Eric
Re: Template for Yadis
« Reply #1 on: February 11, 2013, 06:34:23 am »
Nice work  ;)
Yadis beta team member
Offline metaled
« Reply #2 on: February 21, 2013, 03:55:21 pm »
great,, but how do I install it? I cant find a skins/template dir in my yadis :O
Offline rafal180
« Reply #3 on: February 21, 2013, 04:58:27 pm »
You should have in eg. c:/program files/yadis folder name "templates" and put there downloaded coustom template/skin folder.
Offline metaled
« Reply #4 on: February 23, 2013, 11:54:02 pm »
ahh, here it is,
got it, looks good. thanks!
Offline alfred_dekker
« Reply #5 on: March 11, 2013, 06:53:04 pm »
Using Thumbgen and want to try Yadis now, but only with your template.. I like that.  but how do I download it, get a third party download manager and still doesn't work.. Or I don't know how to do it.... Great template
Med1000x 3D
Med2Xkey
Sony Bravia 46 HX755 3D
Motorola vip 1853
KPN Experia Box, TPLink network switch
Buffalo NAS 2TB
Onkyo TX-nr708   7.1
Twonky Manager, Playon MediaServer
Thumbgen 1.2.10.0
Logitech Harmony One
Offline Mr Eric
« Reply #6 on: March 11, 2013, 07:53:26 pm »
You can't click on the links in the first post and download the zip ?
Offline rafal180
« Reply #7 on: March 11, 2013, 10:52:27 pm »
Links works ok so you shouldn't have problems with download, there is a lot of mirrors if one of them not work try another mirror.
Offline gsf600y
« Reply #8 on: September 24, 2013, 08:30:53 pm »
Hi, thanks for this :)
I've just downloaded, and it's working nicely.
I had to change a couple of things:
1 - template.xml
Changed
    <template name="GLASS Revisited"
to
    <template name="Tribute GLASS Mix"
Otherwise you'll get 2 "GLASS Revisited" options in the Yadis settings menu.
Replaced this file with one of your previews in the opening post.
Also, the download links are a nightmare to navigate.  You've got to be careful not to accidentally click on the junk they try to trick you into downloading.  Would you like me to create a torrent file instead, and seed it on my Seedbox?
Offline Stefanz
« Reply #9 on: September 24, 2013, 09:22:42 pm »
I would certainly appreciate that! Those links are ridiculous - I couldn't get a download an gave up in the end. Also, I've tried loading templates before and they never seems to appear as an option to select afterwards.... what am I doing wrong?  I presume this will work on the latest version of Yadis released this week?
Many thanks
Offline gsf600y
« Reply #10 on: September 25, 2013, 08:46:21 pm »
This Magnet URL should work :)
Code: [Select]
magnet:?xt=urn:btih:0F37FD4EC354B27A0D63DE984704E58C2F1BE406&dn=Tribute%20GLASS%20Mix&tr=udp%3a%2f%2ftracker.publicbt.com%3a80%2fannounce&tr=udp%3a%2f%2ftracker.openbittorrent.com%3a80%2fannounce&tr=udp%3a%2f%2ftracker.ccc.de%3a80%2fannounce
You just put the downloaded folder into the Yadis Templates folder, and restart Yadis, go into Yadis setup menu and select the new template.
You'll of course need to reprocess all your existing movies to apply the new template.
Offline god_man
« Reply #11 on: December 13, 2013, 10:48:35 am »
the yadis is not working, closes automatically
  anyone have the same problem , already tried in several computers , the problem and the same
Offline Cherakos
« Reply #12 on: December 13, 2013, 12:13:21 pm »
Me too also. (win7x64).
I believe that is from yesterday updates from windows update.
« Reply #13 on: December 13, 2013, 12:14:55 pm »
Anyone tried Compatibility Mode to see if that fixes it?
Offline Cherakos
« Reply #14 on: December 13, 2013, 02:27:36 pm »
Yes i tried. No good at all !!!
