Author Topic: X3 Open Fields Skin by Mede8er  (Read 31321 times)
« on: February 10, 2013, 05:27:55 PM »
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
You can customize the skin by replacing the Home Page Background  image 'BG_LAYER1.jpg' with any jpg image 1280x 720 pixels.
Download X3 Open Fields English by Mede8er
Download X3 Open Fields English USA Mede8er
Download X3 Open Fields Dutch by Mede8er
« Last Edit: March 25, 2013, 12:42:41 PM by Mede8er1 »
Re: X3 Open Fields Skin by Mede8er
« Reply #1 on: March 25, 2013, 12:43:33 PM »
USA English version added.
