Poll
Question: Why I dont have audio signal ?
Why I dont have audio signal ? - 0 (0%)
What should I do ? - 0 (0%)
Total Voters: 0
Author Topic: no audio signal on the .mov files  (Read 803 times)
alan
« on: January 17, 2010, 10:37:28 pm »
Hello,
I have not audio signal whan I play .mov files from my digital camera (TELEFUNKEN) on my media player ??
I put the SD card into the media player and there is no audio-signal only the picture ? When I connent camera with the LCD directly, everything is OK.
What sholud I do ??
MED500X
f/w V 1.2.1
connect with the LCD SONY via HDMI
« Last Edit: January 18, 2010, 12:59:53 am by alan » Logged
Insomniac
Moder8or
« Reply #1 on: January 18, 2010, 08:42:08 am »
Hi Alan,
It is quite possible that the audio encoding within the MOV file is not supported, and hence is not playing on the Mede8er.
The only way to tell would be to obtain a full MediaInfo TEXT output from the problematic file in question and/or obtain a small sample via our tech FTP.
Not all .MOV files are equal - this is just a 'container' that is made up of various elements such as audio and video codecs, amongst others...
While the .MOV container and the Video codec of your camera's files appear to be supported, I am led to believe that the audio codec employed by your camera appears not to be.
More detail would be necessary in order to determine this as a matter of fact.
alan
« Reply #2 on: January 18, 2010, 11:20:50 pm »
Hello again,
Here are the details about my video file from my digital camera:
General
Complete name                    : C:\Documents and Settings\Vaillant\Desktop\FILE0001.MOV
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 36.1 MiB
Duration                         : 46s 880ms
Overall bit rate                 : 6 454 Kbps
Encoded date                     : UTC 2010-12-02 18:06:08
Tagged date                      : UTC 2010-12-02 18:06:08
AMBA                             :
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Bit rate mode                    : Variable
Bit rate                         : 0
Maximum bit rate                 : 0
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 29.970 fps
Stream size                      : 33.9 MiB (94%)
Title                            : Ambarella AVC / Ambarella AVC
Language                         : English
Audio
Format                           : ADPCM
Codec ID                         : 11
Codec ID/Hint                    : Intel
Duration                         : 46s 857ms
Bit rate mode                    : Constant
Bit rate                         : 384 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Stream size                      : 2.14 MiB (6%)
Title                            : Ambarella AAC / Ambarella AAC
Language                         : English
Please Info is there any solution for my problem ?
Regards, Alan
alan
« Reply #3 on: January 20, 2010, 04:45:16 pm »
Hello there,
Here are the details about my  .MOV video file from my digital camera (no audio signal, only the picture) :
General
Format                           : MPEG-4
Codec ID                         : qt
AMBA                             :
Video
Format                           : AVC
Codec ID                         : avc1
Bit rate                         : 0
Language                         : English
Audio
Format                           : ADPCM
Codec ID                         : 11
Bit rate                         : 384 Kbps
Language                         : English
Please Info is there any solution to get audi signal to ?
Regards, Alan
tachita
Guest
« Reply #4 on: January 20, 2010, 05:16:27 pm »
the problem is here
Audio
Format                           : ADPCM
this type of codec is a predictive based coding that is actualy not supported. maybe in a future fw release.
