Author Topic: Yadis2mede8er  (Read 251297 times)
Re: Yadis2mede8er
« Reply #30 on: January 18, 2013, 04:39:55 pm »
funkycochise
Great. WIll check it later.
Re: Yadis2mede8er
« Reply #31 on: January 18, 2013, 08:04:46 pm »
funkycochise
Great improvement and just one small issue.
If the 'workspace\data\' has no xml in one or more movie.name folders then 'Yadis2mede8er' crashes. Maybe you can take care if this situation. Short term workaround is to just delete the folder/ folders.
Offline inikad
Re: Yadis2mede8er
« Reply #32 on: January 18, 2013, 10:11:16 pm »
Du très bon boulot!
Great job!  :)
Offline inikad
Re: Yadis2mede8er
« Reply #33 on: January 19, 2013, 08:33:28 am »
I've got a little problem with ratings in jukebox view: in xml and about files, I can see the correct rating for each movie but in jukebox view, all the movies display only 10/10 and five stars rating.
Offline shizzl
Re: Yadis2mede8er
« Reply #34 on: January 19, 2013, 09:49:05 am »
3. Newer movie sort support
Until today, I was sending all movie xml file without restrictions.
Now the copy to target folder is a bit more clever :
    If movie.xml file doesn't exists in target, movie.xml is copied.
    if movie.xml file exists, the applications is checking the last modification date of
    the movie.xml in target and also data.xml in %workspace%/data/movie folder.
    if both date are different, movie.xml is copied.
Desptite this, user may still want to send all the movie.xml, without any date check.
For that it may use the 'Send all' checkbox, It's bypassing all verifications described previously.
In Y2M i added an option to use movie folder date as .xml date.
This way you can update the XML whithout loosing the sort order.
No further checks needed. Maybe you can consider this if it helps
MED1000X3D
Re: Yadis2mede8er
« Reply #35 on: January 19, 2013, 09:58:25 am »
'Yadis2mede8er' needs to take the ratings in Yadis and x10 in order to correct this.
Offline funkycochise
Re: Yadis2mede8er
« Reply #36 on: January 19, 2013, 12:09:33 pm »
Beta 6 is out :
http://www.multiupload.nl/92AD6Z7U9R
Direct Download http://www.mede8er.org/beta/Yadis2Mede8er/yadis2mede8er_beta_6.7z
- rating is *10, normaly it should match your local numbering settings (point or comma decimal separator)
- check is done with for existing yadis data.xml and target folder.
thanks shizzi for your advice, I may change my xml sending decision process.
« Last Edit: January 19, 2013, 12:35:17 pm by Mede8er1 »
Offline inikad
Re: Yadis2mede8er
« Reply #37 on: January 19, 2013, 03:00:38 pm »
Problem solved!  :)
Re: Yadis2mede8er
« Reply #38 on: January 19, 2013, 03:32:52 pm »
Problem solved!  :)
great.
thanks, mede8er1, for allowing direct download from your official site.
I'm currently working on the profile used in Yadis.
I saw that when you set it as Dune, You're allowed to change the type of case (DVD, Blue Ray, Matroska,...)
That's not allowed by the MEDE8ER profile (why ?)
So I've decided to make a support dor use of the Dune Profile in Yadis.
What I've seen :
- In Dune format, Yadis creates
  • dune_folder.txt
  • icon.aai
  • poster.jpg (in workspace movie folder)
  • preview.jpg (in workspace movie folder)
  • fanart.jpg (in workspace movie folder)
So the idea is to clean this a bit to match our requirements to only get folder.jpg and about.jpg
I don't remove any file in workspace movie folder  (as it seems help to retrieve yours processing preferences)
Also, I've seen that poster.jpg, the file that becomes folder.jpg is in a much more hi res definition than in the mede8er settings.
Re: Yadis2mede8er
« Reply #39 on: January 19, 2013, 04:24:30 pm »
funkycochise
We will host your tool with pleasure as we aim to give Mede8er owners a great experience and easy download. ;D
Dune Profile makes a lot of sense as it also opens the Series scraping within Yadis. So I agree with you. Personally I would prefer 'Yadis2mede8er' to write the image files to the movie folders as then you have some control. Currently if you use the Mede8er profile within Yadis is 'auto' writes the images as the scraping is done. This is just just a personal preference of mine as I am used to Y2M that has a 'Copy files to Mede8er button'.
Re: Yadis2mede8er
« Reply #40 on: January 19, 2013, 06:15:39 pm »
funkycochise
Support for dune profile seems to work quite good. I will release beta 6 soon.
You point the aspect of Series support, is it planned to mede8er to support Series ?
Re: Yadis2mede8er
« Reply #41 on: January 19, 2013, 06:56:17 pm »
funkycochise
Mede8er currently does support Series is a Movie Wall structure so it would be normal Media Library browsing and no Mede8er.db required. Will give the the specs soon
Re: Yadis2mede8er
« Reply #42 on: January 19, 2013, 07:04:29 pm »
funkycochise
Ok, I have to admit that it is not my first priority as I don't really care for Series.
That said, I'm still curious to know how you manage this, if it supports larger banner and so.
Thanks again for the constant support for med users.
Re: Yadis2mede8er
« Reply #43 on: January 20, 2013, 07:30:27 am »
beta 6,
http://www.multiupload.nl/A1VU3CLZ5H
Direct Download: http://www.mede8er.org/beta/Yadis2Mede8er/yadis2mede8er+beta+6a.7z
added support for Dune profile that opens several customizations in Yadis
i.e. : type of case
« Last Edit: January 20, 2013, 08:20:29 am by Mede8er1 »
Re: Yadis2mede8er
« Reply #44 on: January 20, 2013, 09:01:06 am »
funkycochise
I like the way 'Yadis2mede8er' works with the the Dune profile and the added advantages of the BD case selection BUT you need to be aware of two issues
1) Sometimes the covers aspect ratio is not 100% so you get a small gap top and bottom
2) Folder.jpg actual sizes vary from  +-50k to 3MB and greater and this substantially slows down the Mede8er Jukebox
For the above reasons I suggest to use the Mede8er profile in YADIS
