Author Topic: Yadis2mede8er  (Read 251523 times)
Offline funkycochise
Yadis2mede8er
« on: January 13, 2013, 05:21:27 pm »
Hi there
The author of Yadis announced that he would fully support mede8er in a coming future.
By the way thanks to him (Frédéric L'hote) for his great work !
As I needed it for now, and didn't want to use something else, I just wrote a small tool to do the job :
Latest build 1.1 : 28/05/2013
http://www.mediafire.com/download/u93lpwg0dv5hp33/Yadis2mede8er_1_1_280513.7z
Mede8erize generates xml files for each movie in yadis folder and copy it to matching movie folder.
Folderize looks for movie files in movie folder, create a newfolder for that movie and copy the movie file inside.
Movie folders are the ones set in Yadis.
Note : using folderize may take a while to complete, especially with remote NAS. So if your files doesn't appear right away after process ended in GUI of yadis2mede8er, it's normal : just wait several minutes.
Basic Guide for Beta 13
Basic Guide Mede8er Aggregate JukeBox
http://www.mede8erforum.com/index.php/topic,10217.0.html
Even if GUI has changed a bit, previous guide for aggregate jukebox remains usable : settings Tab ishouldn't disturb that much
FKY
« Last Edit: August 12, 2014, 04:25:19 pm by Mede8er1 »
Re: Yadis2mede8er
« Reply #1 on: January 13, 2013, 05:53:15 pm »
funkycochise
Fantastic News ;D
Why dont we open a Beta Test group for this?
Well done.
« Last Edit: January 13, 2013, 06:10:08 pm by Mede8er1 »
Re: Yadis2mede8er
« Reply #2 on: January 13, 2013, 05:57:15 pm »
GREAT!
I am sure a lot of community members will love this....
Re: Yadis2mede8er
« Reply #3 on: January 14, 2013, 07:44:39 am »
funkycochise
Fantastic News ;D
Well done.
Hi mede8er1,
just wait for the first release. It should arrive these days.
is there somewhere a template available for the movie.xml recognized by mede8er ?
Re: Yadis2mede8er
« Reply #4 on: January 14, 2013, 08:19:30 am »
funkycochise
Great ;D
I suggest you use the attached sample XML as a template as it has all the fields that the Mede8er requires to show XML info and for the Movie JukeBox.
Re: Yadis2mede8er
« Reply #5 on: January 14, 2013, 08:49:05 am »
funkycochise
Great ;D
I had my template from the one generated by DuneX. I can see that are no info about the media here, so I can remove some markup i am currently exporting.
All fields you specified in attachment are exported by now.
Re: Yadis2mede8er
« Reply #6 on: January 14, 2013, 09:25:51 am »
funkycochise
Correct we just use the fields as foll
<details>
<movie>
 <title></title>
 <year></year>
 <rating></rating>
 <plot></plot>
 <runtime></runtime>
<genres>
 <genre></genre>
 <genre></genre>
 <genre></genre>
 </genres>
 <director></director>
<cast>
 <actor></actor>
 <actor></actor>
 <actor></actor>
 <actor></actor>
 <actor>i</actor>
 <actor>i</actor>
 </cast>
 </movie>
 </details>
Offline rickavmaniac
Re: Yadis2mede8er
« Reply #7 on: January 14, 2013, 01:18:58 pm »
Great  work !
I would like to test that  :)
Offline couto
Re: Yadis2mede8er
« Reply #8 on: January 14, 2013, 02:13:19 pm »
to test count  me in.
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Re: Yadis2mede8er
« Reply #9 on: January 14, 2013, 08:33:16 pm »
Here we are :
http://www.multiupload.nl/0SYQ5OTUTP
There is a setting for the program, Yadis Workspace folder :
default value is : C:\Program Files\yaDIS\workspace
Of course if for you this isn't the case, please change it in file yaDIS2mede8er.exe.config
in yadisWorkspacePath
            <setting name="yadisWorkspacePath" serializeAs="String">
                <value>C:\Program Files\yaDIS\workspace</value>
            </setting>
You can check those 2 features :
- mede8erize :
scan all movies in Yadis ans create an xml file formated for mede8er.
known bug : if a movie exists in Yadis but that is still not treated, yadis2mede8er will crash.
- folderize :
scan all folder declared in Yadis. It looks for movie files mkv or avi.
When found, it creates a new folder with the movie name, and then moves the movie file inside.
Additional tips : I declared my shared folders as mapped drives, I didn't test with network path.
Have fun.
FKY
Re: Yadis2mede8er
« Reply #10 on: January 14, 2013, 09:04:49 pm »
funkycochise
That was real quick and we thank you for this. Will start to test in the morning
Re: Yadis2mede8er
« Reply #11 on: January 15, 2013, 05:35:59 am »
funkycochise
Tested and the 'Mede8erize' is creating a 'movie.name.xml' in the Workspace folder but this is not copied to the movie folder. Tests done on local drives and not Network Shares.
 'Folderize' ?? What does this do
- folderize :
Re: Yadis2mede8er
« Reply #12 on: January 15, 2013, 07:48:46 am »
funkycochise
Hi thanks for the test.
It's weird that's not copied.
mede8erize :
1. I look for folders inside workspace\data\
2. I have then an array of folders.
3. For each folder, I get the data.xml
4. Based on that file, I build the movie.xml based on the name of the movie folder.
5. Inside data.xml, I also get the information where the target folder and file are located.
6.  I copy the movie.xml to the target dir.
Folderize :
1. Get Informations from folder.xml inside  workspace\
2. So I have an array of path that are set in yadis
3. I look inside a path, searching for movie files (avi and mkv)
4. There I have an Array of files
5. For each file, I create a folder based on the name of the file.
6. I move the movie file into that folder.
Is it more clear ?
Could you post a screenshot of your log screen or explain a bit more your installation
maybe I could create a logfile for the beta test.
Note : folderize, as tested by myself may take time to be completely achieved,
especiallay using remote shared folder. During my test I often thought tha file would
appear in the folder but finally It does it well.
« Last Edit: January 15, 2013, 08:24:16 am by funkycochise »
Re: Yadis2mede8er
« Reply #13 on: January 15, 2013, 10:42:27 am »
funkycochise
We tested this again with the same results. Waited a long time and still the xml files were not written to the Movie Folders
Pls check attached screen capture
Re: Yadis2mede8er
« Reply #14 on: January 15, 2013, 10:57:05 am »
So your workspace is E:\YADIS_TEST
here you have the data folder with all your directories.
What is the final location of the movie ?
PS : maybe tou could zip me your YADIS_TEST Folder, so I could try to find out what is wrong.
by the way, what is your OS ?
As you experience a long wait between each movie I suppose, I'm pretty sure that it's a matter of
move function trouble.
normally, you have should have these messages :
Processing 'MyMovie'
Drive:\moviefolder\MyMovie.xml successfully created.
Maybe I should add a target folder availability check before running.
« Last Edit: January 15, 2013, 11:11:58 am by funkycochise »
