Author Topic: new to mede8er and need help  (Read 13123 times)
Offline monk74
« on: January 09, 2013, 04:50:56 PM »
Hi all
am totally new to mede8r and am running a mac. I have put on all the movies, but would like to know the best catalog/database to use for the movies info. Am also not sure how to use Dunex as there is no user's manual. Can someone walk me through the steps and process of having all the movies cataloged on Mede8er 1000x3D
thanks
Offline stonehound
Re: new to mede8er and need help
« Reply #1 on: January 14, 2013, 07:20:15 AM »
Do you still need help on this?
Offline monk74
« Reply #2 on: January 14, 2013, 06:53:32 PM »
Hi Yes
I have exported the files to Dunextomede8er, but it doesnt give any info although there is a green dot on some of the titles.
How can I change the database it uses to get the info?
Out of all the movies, it only got the plot for american reunion and not even the poster??
RR
Offline mognons
  • printf("Hello, world! \n");
« Reply #3 on: January 15, 2013, 07:36:56 AM »
DuneX2Mede8er it is not a scraping tool: movie info are taken from the XML library of DuneX. You still have a chance to override some of those info with data gathered from TheMovieDb data. Sorry, but you cannot change the DB source.
If you can't see movie in DX2M8 that means that no info is present in the original (DuneX) library. You can easily check within DuneX what info/posters are displayed when you scan your library.
Proud user of DuneX2Mede8er
