Author Topic: Media software links  (Read 113465 times)
Offline mysticc
  • B8a Tester
Re: Media software links
« Reply #15 on: December 09, 2009, 09:30:48 am »
Is there a way to accomplish showing the coverart when a folder is selected and when going into the folder showing the film-description stored in another .jpg automatically?
Right now I have to select the .jpg with rendered film-description manually.
Would need Mede8er to not only picking 1st .jpg but make his choice by looking at the name of the file I guess.
V3.0 Beta
MED500X with internal HD 250G
100Mbit Networked with CAT5 to AVM Fritz 7220
Networkshare mainly on Win2003 Server, sometimes on Windows7 x64 Ultimate
Connected via Component to LCD and HDMI to projector.
AVR: Denon-3805
Projector: Sony HW-10
LCD: Viewpia 37
Blu-Ray-Player: LG BD 370
Offline Julian Cohen
« Reply #16 on: December 09, 2009, 10:27:31 am »
I recently installed Media Browser on my PC. Is there a way that the covers, and movie information could be displayed on my Mede8er preview screen?
Mede8er MED500X #1: f/w v2.0.2 / PVISION 40" LCD PLX40T > HDMI > 1080i 50HZ > 16:9 /  Harmon Kardon Receiver AVR 300RDS > Stereo RCA > Night Mode Off / Wired Network > Windows 7
Mede8er MED500X #2: f/w v2.02 / Optoma HD20 > HDMI > 1080P 50HZ / Yamaha RX-V2065 Receiver > SPDIF > Night Off
Offline Insomniac
  • Moder8or
  • B8a Tester
« Reply #17 on: December 09, 2009, 12:26:09 pm »
Hi mysticc,
Already answered in MPCClub:
We'll look at ways of fine-tuning this later on - it makes sense to be able to render them in the manner you have described. We'll have to establish a naming standard to accomplish this though - hopefully one that is already considered a 'standard' so that one doesn't have to maintain multiple files for different media players.
Offline mysticc
  • B8a Tester
« Reply #18 on: December 09, 2009, 12:30:53 pm »
Me too.
Will focus on this forum for Mede8er-talk.
In Movie Gui Builder you can define how the files are namend that are created, so any name-definition of Mede8er would work with this SW.
Any quasi-standard that matches most of the SW for that purpose out there? - I am not aware right now.
V3.0 Beta
AVR: Denon-3805
LCD: Viewpia 37
Offline Insomniac
  • Moder8or
  • B8a Tester
« Reply #19 on: December 09, 2009, 12:53:12 pm »
Personally I like to look at XBMC because much discussion takes place in their forums as to the pros and cons of the various standards.
They have come a long way and it seems silly to re-invent the wheel...
As a general rule though we are using 'about.jpg' as the name for the movie synopsis JPG, with the possibility of using 'folder.jpg' for the folder cover-art.
Perhaps we need to start a thread to discuss this topic in it's own right rather than use the Software links thread...
Offline TimoLimo
  • B8a Tester
« Reply #20 on: December 09, 2009, 03:49:04 pm »
Sounds like a plan :)
I'm using the Mede8or and my old trusty TViX M-4100SH to stream all my HD media files. But since the 4100 only has a standard def GUI, I will be obliged to redo all my cover art and movie info jpg's, as it looks really crappy on the Mede8or, especially the cover art (please note: NOT the mede8or's fault ofcourse ;) GIGO-principle: Garbage In, Garbage Out  ;D)
As about.jpg and tvix.jpg are two separate files, I see no problems with that, both mediaplayers can work with their 'own' movie info formats.
But they both will take the folder.jpg as cover art. And then I'm a bit screwed, bigger/higher resolution folder.jpg's will be nice on the Mede8or, but will slow down the tvix dramatically, or not even show.. Small, low-res folder.jpg's will make the tvix fly, but it's low quality will make my eyes water when they are displayed through the Mede8or on my 50" FullHD plasma.
Well, it's not really Mede8or's problem, this specific situation I find myself in, so I don't really expect anyone to take this into account.
Maybe my solution lies in a future firmware where, like on the tvix, we see 10 (or more) icons without preview per page, instead of a list plus preview.
And maybe that way, the small resolution of my 'old' folder.jpg's won't be so obvious (actually, like it is on the tvix now).
Well, thanks for reading :) I was actually going to make a point, saying automatically using folder.jpg and about.jpg as naming convention is very good. Can't wait to see it implemented.
Mede8er model: Mede8er FW 4.0.5 (non-DD+)
Hard disk: WD Caviar Green 2TB, WD20EADS,
Network: CAT6 LAN 100Mbit/1Gbit, connected through D-Link DIR-655 router and D-Link DGS-1008D switch
PC: Windows 7 Home Premium 64-bit
NAS: Thecus N7700 (NFS+Samba)
Display device: 50" Pioneer KRP-500A, connected via HDMI
Audio: Yamaha RX-V2095 via COAX S/PDIF
Offline mysticc
  • B8a Tester
« Reply #21 on: December 09, 2009, 07:39:57 pm »
A list of coverart only standing for themselves as many players do - yes, second that, would love to see.. :-)
V3.0 Beta
AVR: Denon-3805
LCD: Viewpia 37
Offline Nielson
« Reply #22 on: December 16, 2009, 07:13:43 am »
Offline astreau
« Reply #23 on: January 04, 2010, 12:06:29 am »
I use DVD Shrink for re-authoring and recompressing DVDs. Its old but it works and its free. And now that ver2.0 will play VIDEO_TS folders directly and 1Tb drives grow on trees I just save the vobs straight onto the Mede8эr
[url][http://www.softpedia.com/progDownload/DVD-Shrink-Download-4128.html/url]
Offline Maudrid
« Reply #24 on: January 04, 2010, 12:53:10 pm »
The "hardlinker"  link is dead
Offline Insomniac
  • Moder8or
  • B8a Tester
« Reply #25 on: January 06, 2010, 01:21:46 pm »
Added
Fixed
Offline Kavi
« Reply #26 on: January 19, 2010, 01:03:09 pm »
I have been using freeware called "format factory" for months now. Please add to the list. Awesome software. Visit www.formatoz.com. Converts almost anything to anything...lol
Mede8er
1.5 TB HDD
Offline beartiger
« Reply #27 on: January 20, 2010, 10:01:18 am »
Have you considered adding AnyDVDHD from Slysoft? It allows you to strem a disk from the PC (it removes encryption) and also to rip a copy un-encrypted to your hard drive.
http://www.slysoft.com/en/anydvdhd.html
beartiger
Mede8er MED500X (HDMI Video & Coaxial Digital Audio Passthrough)
Pioneer VSA-E03 Dolby Digital 5.1 AMP
Panasonic Viera TX-P37X10B 37" Plasma TV
Devolo HD 200mbps HomePlug Network
Offline Insomniac
  • Moder8or
  • B8a Tester
« Reply #28 on: January 24, 2010, 01:46:43 am »
beartiger
Updated first post
Offline Jan Pl
« Reply #29 on: January 29, 2010, 12:51:51 pm »
Hi Insomniac,
Do you have something for TV-Shows? and how to use it? Pls
I've tvixie for movies!
Jan
